Question about Kenmore Refrigerators
How do I rempve the pur water filter from my cold
How do I remove the pur water filter from my cold spot side by side frig
    Guru:
  • 1,524 Answers
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
How to remove the Pur water filter from the bottom of a KitchenAid side by side Refrigerator
It is a push-button filter located in the grille at the bottom of the fridge. Simply press the release button to remove and replace the Refrigerator Water Filter Cartridge.
Sep 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water delivery and ice production
Get a good connection to the cold water line, buy a good filter and run copper to the back of your refrigerator. Don't use a piercing valve. I know how you feel. Oh, put shutoff on side of filter housing that feeds the filter. Sea Breeze
Aug 18, 2009 | Samsung RM255LASH Side by Side...
I own a side by side black-n-stainless fridge and I bought a kit for the water/ice despenser, installed it as per instructions but not getting any water in the ice maker or out of the water. The water is...
If its got a filter under the frig. just hook your water to the house water line. If not then put a filter in the cabnet next to your frig. Or in a handy place to get to. And you will have to hold your water lever for a long time till all the air gets out of the line. there is a extra long hose you must fill up in your frig side. It is used to keep cold water ready to drink.
hope this is helpfull
Aug 12, 2009 | Frigidaire FRS26R4A Side by Side...
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
No water being removed
Hi, Firstly I would check to see if there is an air filter screen inside the machine - usually just behind the intake grille. They can be tricky to spot. If the filter screen is clogged up with fluff it will prevent the machine from working properly.
Secondly, can you see any signs of ice or condensation on the cold pipes? If not, and the compressor is running - a purring or throbbing sound - your machine might have a refrigerant gas leak. You would then need to get it checked / repaired by a regrigeration engineer.
Does this help? If not please give further details and ask again. Thanks.
Jun 30, 2008 | Maytag M3DH30B2A Dehumidifier
Water not cold anymore
the tank in the fridge may have a block so only the warm water is coming in and not cycling thru the tank to be chilled? would be my best guess
Jun 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
