Question about KitchenAid 24 in. KUDG25SH Built-in Dishwasher
Help! Same white residue and even pro can't figure it out!
Help! Just like another poster, my top rack dishes have a white residue on them. I have tried everything suggested (Cascade detergent, Jet Dry, white vinegar rinse, running hot water first) with no luck. I've even had a pro repair person come out twice and he told me it's just soap built up. Lately I think my lower rack dishes aren't getting clean enough either. Any suggestions? How can I check for a clog on the spray arms?
  • 2 more comments
  • leeni8 May 03, 2010
    Thanks Phil - any chance it could be the check valve and/or chopper? I've read that could be a problem. Is that a costly repair?
    Phil,
    You are the best! Model number is KUDG25SHBL1.
    Phil,
    President:
  • 949 Answers
It sounds like a washability problem. A couple of things to check.
See if the bottom and top spray arms are free turning. Then look closely at the holes to make sure they are not plugged with anything.
The rest of this applies if you have mode KUDG25SH, if you have a different model number on the tag inside the door let me know and ignore the rest here.
You may have a split in the upper spray arm feed tube. If you slide the upper rack out and look under it you will see the spray arm(propeller looking) under and behind there is a vinyl tube also attached to the rack, look that tube over good, if it is broken or cracked you are loosing water pressure that does the washing.
Let me know what you find and I can help more if needed
Phil
Posted on May 01, 2010
  • 1 more comment
  • Philip May 03, 2010
    If the residue is from detergent it could be due to the sump area around the chopper or the chopper itself. I put together some instructions on how to access, clean and check that area. I have attached the link below to those instructions.
    If you do take it apart the check valve can be accessed at the same time, it is part number 5 in the diagram it sits in a little slot just the right of the copper sump area, you can only see the top of it once you are in there, but can take a needle nose pliers or tweezers and pull it out to check it.
    Let me know if you have more questions. I would be happy to do my best to help.
    http://www.fixya.com/support/r4628450-po...
    Hi again, I am sorry the check valve and chopper I sent the instructions for are on the tall tub KitchenAid model, yours from the model number on the report here is a standard tub dishwasher. If you could send me the model number from the tag just inside the door I can make sure I am giving you the proper procedures for the dishwasher you have.
    Phil
    Below is breakdown of your pump. Part 19 is the chopper and to be honest I have never had one go bad in this model, it is somewhat common on the tall tub but never on this model.
    The check valve is part 15, the only thing that fails on this is it can get plugged up with seeds or toothpicks or other foreign objects, if this were to happen you would not be draining the water out of the tub.
    If you can see it, take a look at the screen on top of part 9 just below the lower spray arm. You are looking to see if the screen is plugged up with the white residue. If so it needs cleaned (vinegar works good) or replaced.
DISHES ON TOP RACK NOT GETTING CLEAN, GLASSES HAVE A HAZY RESIDUE.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Maytag Dishwasher
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
Top wash arm does not move under water pressure,but moves freely by hand, leaves soap residue on top rack. not clogged and bottom works ok model # fdb750rcc
heatman101
''ll';l;
Aug 19, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
We have a problem with a gritty residue on our dishes. Not sure what it is but it's worse on the top shelf. Almost a guarantee that the entire top rack has to be hand washed. Any suggestions would be...
heatman101
Jul 19, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Top rack dishes have a white gritty residue on them. i use washer cleaner and jet dry and it does not help. i don't know if there is filter to clean or not . what do i do?
Check whether the top rackspray arm is moving freely. Check the jet holes and remove clogs if any.
Hope the bottom rack is good in wash quality!
Apr 12, 2010 | KitchenAid 24 in. KUDG25SH Built-in...
My dishwasher leaves white residue on cups of the
heatman101
Feb 15, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid 24 in. KUDG25SH Built-in Dishwasher Logo
162 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
