Question about GE JVM1650 1000 Watts Microwave Oven
My microwave will run for about 3 to 5 seconds and then turn off and I have to reset the clock and date. Then it will go again and do the same thing. What could maybe be wrong?
    Genius:
  • 1,417 Answers
Hello'
accorddind to the information pass across this means that your oven develop what is call partial contact this partial occur within the maize and the element i.e the wire which pass con rent from the ac to the microwave it self or the heat provider
these wire can be in two or three colour red and any other colour,
this occur when ever your microwave is about to heat up proper
what you need to do is that un scroll your oven to trace the wire connected to element to see which of the wire have been disconnected
after you being able to get which is loss from it position then look at who others are connected then replace the loss wire ti is position then your microwave will then work again has it's expected to
please note this while doing this make sure that your microwave is not connected to any form of power supply.
Good luck and thanks for using fixya.
Posted on May 01, 2010
  • 1stTimeFix Dec 08, 2010
    what is happening is your magnetron tube is leaking RF and causing your board to short. The magnetron tube will need to be replaced.
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
Microwave JVM 1660wbooi unit runs for two or three seconds and shuts down locks up if i unplug the uni and plug it back in it will reset and try to start again same problem if i repete this 3 or 4 tim
This is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
See
this FixYa solution. even if your model number is different.
http://www.fixya.com/support/t2330691-ge_spacesaver_jvm1650sh01_shuts_off )
Oct 16, 2012 | GE JVM1660 Microwave Oven
Thing worked fine and then recently started on this inccessant clock reset thing?
Well the only way to fix it, replace the keypad control board, but consider the cost in parts, it will rival some new microwave ovens.
Apr 09, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Turn off Demo Mode on goldstar Microwave
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
Otherwise, try holding CLEAR for 3 seconds, then try each pad for 3 seconds.
Sep 07, 2008 | Goldstar MV-1615 Microwave Oven
Microwave stops working
sorry to say the control panel sounds like it is defective.There is a microwave guy here that repairs these panels, look him up and contact him for the panel repair information. Good Luck
Apr 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
277 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
