Question about RCA L32HD36 32 in. LCD HDTV
Change menu selection from Spanish to English
I hit a button on my RCA remote control and the menu selections were converted to Spanish. I want to change the menu selections back to
English and need help with the steps.
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
SOURCE: Why can't I find the codes for DirectTV remote?
If you have a 32 inch polaroid when you scan it will be the 2nd code. I have a 40 inch polaroid and have not found the code yet. Good luck.
Posted on Nov 28, 2007
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
SOURCE: OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
Posted on Dec 09, 2008
  • 225 Answers
SOURCE: How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Posted on Jan 08, 2009
My Philips 47PFL7422D/37 sound keeps defaulting to Spanish. I know how to reset it with the remote, but it just defaults back immediately.
Hi the link below has a FREE user manual download in it but the question and answer should help you........CHEERS..
QUESTION
I have lost my personal settings. Why is this?
Your personal settings were probably reset after you had switched off your TV because it is still in the LOCATION SHOP mode. In this mode, all settings are fixed and will automatically apply each time the set is turned on.
ANSWER
To store your personal settings, make sure your set is in LOCATION HOME mode:
1. Press the MENU/BROWSE key on the remote control.
2. Select TV menu and press the button
3. Select Installation and press the button
4. Select Preferences and press the button
5. Select Location and press the button
6. Select Home and press the OK button
7. Press the MENU/BROWSE key to browse through the menu
Philips flat HDTV 47PFL7422D 47 LCD integrated digital with Perfect Pixel...
Apr 04, 2016 | Philips Televison & Video
Change language from spanish to english
Try going to your menu button or setup button on the remote. Look for the word "Idioma". That is spanish for language. Once you select ENGLISH to change, make sure you follow the exit instructions so it will be memorized
Mar 31, 2016 | Magnavox 39MF412B/F7 Widescreen 39 Class...
Remote is set on spanish I need English
Language selection is made during initial setup of the TV. The remote has nothing to do with language selection.
Nov 20, 2013 | Coby TV Remote Control
I have a rca colortrak plus and lost the remote. How can i set it up to work with a converter box? It is displaying in spanish and I can't change back to english
You may be able if can enter the menu to change from Spanish back to English--(very old set) by using vol or channel buttons to navigate--this is not certain but possible--idioma is word to look for--language.
Apr 25, 2012 | Televison & Video
Four issues: 1. I am 84 years old and cannot understand the manual directions. 2My voice mail demands a password;never used one. 3. Voice control is in Spanish. I read and understand English. 4 Phone...
Voice Mail is a network feature. Please contact your service provider for configuring the password, or removing it, and to change the Voice control from Spanish to English.
If your Phone Display is in another language other than English, the following instructions will apply:
Changing the display language Note: This is the only Language configuration for this phone.
  1. Press the {MENU} button on the handset.
  2. Use the Up and Down arrows on the Handset and select the menu "Handset settings", followed by the {OK} button.
  3. Use the Up and Down arrows on the Handset and select the menu "Display settings", followed by the {OK} button.
  4. Use the Up and Down arrows on the Handset and select the menu "Change language", followed by the {OK} button.
  5. Use the Up and Down arrows on the Handset to select the desired setting.
  6. Once the desired setting is found, press the {OK} button, followed by the {OFF} button.
Jun 04, 2011 | Panasonic Cell Phones
Everthing is in spanish-how do I change it to english
Hello
To change the on-screen language do the following
The Plug In Menu comes up automatically
when you first turn on the TV a f t e r
plugging it in. The Plug In Menu sets the
default preferences for you for.
If plug in menu doesn't appears automatically, "simoultaneously press "Menu button & Volume (--) button on the TVs' front panel.
Surf through the on screen menu with the help of [right arrow, left arrow, down arrow and up arrow] buttons to select the langauage option.
Your JVC television allows you to
choose from English, French, or Spanish
o n - s c reen menus and displays
Hilight the language you wants from the list. There are three languages are to select.
After selection is over hit Exit button on the remote control to exit the plug in menu.
OK
Dec 31, 2010 | JVC AV-32920 32" TV
How do i get the language back to english?
Hello
Press the Menu Button on the remote to show on-screen menu.
Press Cursor Up or Down button to scroll through the on screen menu until the word Install is hilighted.
Press Cursor Right button to display the Install menu features.
Press Cursor Up Or Down button to scroll the install features until the word Language is hilighted.
Press Cursor Right button repeteadely to select English or Spanish [Espanol]
When finished press the Status/Exit button to remove the menu from the TV screen.
[The language control only makes the TVs on-screen menu items appear in English or Spanish. It does not change the other on-screen text features such as Closed Caption [CC] TV shows.]
Ok.
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
Television only plays in spanish
change language from service menu.
Jul 06, 2009 | RCA F27442 27" TV
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
Wrong language
In the menu one of the first options is language. If it is in spanish you may have to get someone that reads spanish to tell where this option in the menu is. Most new remote hand units have up and down and side to side arrows. Clicking the right side arrow usually will make selections, When you get to english if there is a select button or enter in the middle of the arrows, push that button if english is high-lighted or underlined or different color. Paul
Sep 23, 2007 | RCA E13319 13" TV
RCA L32HD36 32 in. LCD HDTV Logo
325 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
