Question about Heritage Pool and Cover Pump
Can you set up a heritage pool using sand to level the surface
  • 990 Answers
Ues you can. If you wet the sand down you can float it out and it will tamp into place very well. Be sure to tamp it out first while it is wet so you don't get soft spots that will let the liner stretch and be supseptial to holes. If you get a soft roll foam to cover the sand with it will be that much stronger.Good luck.
Posted on May 01, 2010
Ph level is at 'ideal' chlorine level is at 3.0 but the pool water is still cloudy. Please help?
The cloudiness could be suspended particles or algae. Use an algae k i l l er as recommended, then a flocculant (water clarifier) as recommended, then vacuum the pool bottom and run the filter overnight.
After that check the ph, alkali level, chlorine level, and adjust as needed. That should do it.
Feb 05, 2017 | Pool & Spa
Our pool is about 90000 litres of water so how big filter do we need please
If you have a above ground pool go with the Cartridge or sand, and if underground go sand or D.E. All have their ups and down you should find out what you want from them specifically cause they all do varying amounts of the same thing.
Sand Filters
(Filters using literally sand)
For sand filters, on inground pools, I like to use a 30 inch tank diameter, which is a 4.9 sq. ft. filter surface area, and holds 600 lbs of sand. For small pools (under 20,000 gals), I might advise the next size down (24 inch tank), if the budget is tight. But never go smaller than a this for an inground pool.
Cartridge Filters (like a air filter)
I have a rule of thumb for cartridge pool filters. 100 sq. ft. of filter surface area per 10,000 gals of pool water, as a minimum. I like to see the 400 sq. ft. models on inground pools above 25,000 gals. These can go an entire season without cleaning in most cases.
D.E. Filters (Ground up fossilized algae)
Because they offer the most superior type of filtration, people tend to go small with DE, and buy a 24 or 36 sq. ft. DE filter. Ugh - go Big! Nothing below a 48 sq. ft. filter, and if your pool is over 25,000 gals, go with the Big Boy - the 60 sq. ft. filter.
Swimming Pool Blog
Also make sure the filter can take the amount of water that the pump is pushing through it.
Jul 23, 2015 | Pool & Spa
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows:
chlorine 1.0 - 3.0 ideal
ph 7.4
alkalinity 100 ppm
calcium 200 ppm
stabilizer 50 ppm (saltwater pool 25 ppm)
These values will provide balanced swimming pool water
Jul 01, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Swim n Play filter system motor frozen after less than two months use on my Heritage 12x42 round pool. What can I do?
Sorry to say, the pumps and filters that come with this type of pool are very low quality built, and not really intended to last long at all! Sorry, but the adage really applies here: "You get what you pay for"!!!
If your budget allows to replace with a "Real" pool pump and filter system, do it and get the good stuff.
Not this:
But get something like this:
Hayward S166T92S Pro Series 16 Inch 1 Horsepower Top Mount Sand Filter...
Good Luck
Aug 17, 2013 | Heritage Arms Heritage Round 12 x 42" Deep...
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
. I am setting up my new intex pool and it is
Is the ground the pool is sitting on, level? If not, move the pool or use sand to create a level base for the pool.
May 01, 2011 | Intex 15' X 42" Easy Set Pool Complete...
My pool is not level by 2.5 inches. Will it
Drain and move to level ground . or add sand on the low side to keep it level
The Pool Tech
Jul 12, 2010 | Intex Frame Set 12 ft x 30 in Pool with...
I have tried setting my pool up three times now, and my ground is not the most level but on the box it says you cannot use sand. What do you suggest??
I assume you're putting up an above ground pool. I use 4" thick x 8 x16" patio blocks under each column. I level each block by starting at the lowest area, and place first block. I then dig out enough dirt to level the next block to the first, and so one. Once you're done, all the uprights will be level. Then, once the metal is all on, I level the inside with sand, tapering it slightly to the center, so the dirt flows to the middle when it settles. There is no problem with sand under the liner, but not under the uprights, as it cold washout.
Jul 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
HAYWARD SAND FILTER, PRO SERIES: sand is getting into the pool whan the filter is r...
Have you tried backwashing recently? If so, I would first check to make sure that your pool filter is on the "filter" setting and has not been changed. Next, i would evaluate your filter pressure to make sure that it is at an acceptable level. Finally, check your sand. If it is extremely dirty or has not been replaces in a long time, it might be time for fresh, more effective sand.
May 17, 2010 | Hayward SAND FILTER, PRO SERIES
Heritage Pool and Cover Pump Logo
Top Heritage Pool & Spa Experts
john h
Tom Chichester
David Spradling
David Spradling
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
