Question about Dell OptiPlex SX270 PC Desktop
Optiplex SX270 LED light code
I have a Dell Optiplex SX270, just replaced the motherboard and now i have a LED code but cant figure it out. Lights A dn B are yellow, while lights C and D are green. any ideas?? Thanks.
    Novelist:
  • 138 Answers
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
Posted on May 01, 2010
Why wont my optiplex 210l will not turn orange light is on
Normally, the amber power light means either a power supply or motherboard issue. There should also be lights on the back numbered 1-4 that give a specific error code depending on which ones are lit up. Here is a link to the manual so that you can figure out what the LED codes mean:
Dell OptiPlex 210L Quick Reference Manual Diagnostic Lights
Sep 02, 2014 | Dell OptiPlex 210L N (210LNDCELMIN) PC...
Dell optiplex sx270: loud, steady noise like an alarm a few seconds after I turn on the PC
You can check the meanings of the error beep codes HERE. Every beep code means something different. The bad thing is that the code I think you are speaking of is a fatal error.
Good luck
Aug 26, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
My Dell OptiPlex 260 won't power on. There's power to the cable (LED comes on on the block) but no lights on the PC....any suggestions?
Do you hear a fan running? If not, it sounds like your power supply needs to be replaced.
If it's under warranty, Dell should be able to send one out right away. If not, you may have to purchas one through them.
Good luck on this. And let us know how you make out.
Cheers,
TIH
Dec 27, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell optiplex sx270 version PC.I had shut it down ,as we had a holiday the next day.I later tried to switch it on after my holiday .But it won't switch on .However the power adapter indicator...
it seems like the power button is at fault i doubt it will effect your data unless you pass it to a bad repair man who may erase everything your hard drive is a seperate entity and can be removed for backup
Aug 06, 2009 | Dell OptiPlex SX270 PC Desktop
COMPUTER GOES ON THEN SHUTS DOWN
I would say this is a hardware issue. nothing anyone online can do for you with this type of issue unless you recently chaged something.
May 28, 2009 | Dell OptiPlex SX270 PC Desktop
Computer does not start. Replaced motherboard and RAM. Hear the fan when I start the computer
The monitor has the problem. the message only means, the connector is not properly connected on motherboared . please try another monitor.
I am sure about this...monitor or the connector ( as u have changed the motherboard) of the monitor has the problem.
Apr 19, 2009 | Dell OptiPlex SX270 PC Desktop
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Blown dell motherboard
Have you checked to make sure it wasn't the power supply? If this motherboard is still inside the pc and the cd/dvd lights up, or the network card shows life, fans, case lights, etc: than I would rule bad mobo. If nothing shows signs of life, try power supply or even better maybe a lose connection.Check all cabling and wire plugs. Clean out any dust.
Dec 29, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
Dell OptiPlex SX270 PC Desktop Logo
911 people viewed this question
Alun Cox
