Question about ASUS P5RD1-VM Motherboard
Installing XP = BSOD
When I am installing XP, it goes fine until the part that says "Setup is preparing Windows". Then it gives me Blue Screen of Death! Please help!
    Novelist:
  • 138 Answers
Hello
Without the actual info from the BSOD, we have to provide general troubleshooting tips.
Since Windows is not yet loaded, it cannot be a driver or software issue - so we need to look at the hardware.
Typically, a faulty or unrecognized RAM stick and / or an unusual BIOS setting can cause this issue.
Go into the BIOS and reset the BIOS to factory defaults, remove all CPU overclocking.
Remove all RAM and try booting with only 1 stick installed.
If this does not work, try and give the error message from the BSOD and we can look into it for you.
Posted on May 01, 2010
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
I have a laptop pc ( compaq presario cq60) vista O.S base model.now i want to install windows xp on that. when i installing windows xp a blue screen come and stop my process. please give an solution for...
Hello
In the setup process for xp,you need to delete and format any partition on drive c.
This will completly erase any vista os files and allow xp to install.
Mar 31, 2011 | Computers & Internet
I cant installed the windows OS , its always giving me a blue screen windows. then it will stop installation. pls help me, thanks
first tell me what kind of windows your installing and what kind of BSOD your getting. every BSOD has a specific codes starts with 0x0. if you can provide thouse information maybe i can help you
Mar 27, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
I hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
Will not load windows,installs all of the files, but a blue screen appears, with error codes
I had the same issue with my Toshiba Sattelite L305 and I had to send to Toshiba to repair, hopefully your is under warranty
Dec 10, 2009 | Toshiba Satellite A105 Notebook
I have a dell dimension e520 and I just bought a wd 320 gb sata hdd. When I want to install xp it stops before the welcome to setup screen and it gives me a blue screen help please
The blue screen you are seeing is probably not the regular BSOD (blue screen of death)
Wat you need is the DOS SATA drivers for your adaptor on floppy or some other suitable form (USB formatted as a floppy)
I think you may have missed it but as the XP CD is booting at the bottom of the screen was a message that said "press F6 to install additional storage drivers"
You should have hit F6
In a little while it will then ask you for those drivers and you just point it at the floppy or other device set to act as a floppy.
Now it will load them and let you continue setup.
otherwise it will quite often fail as it may no know how to find the SATA drive.
Sep 07, 2009 | Dell Dimension E520 PC Desktop
Having major problems installing windows XP
Your motherboard has a bad on board hardware. Its hard to fix that eventhough you disable the function on it. Its better to buy a new motherboard.
Jul 24, 2009 | Microsoft Windows XP Professional Edition...
BSOD at start of Windows XP Setup
try F8 to got to the startup menu, and choose last known good configuration, use a ps2 keyboard or an adaptor and nothing that needs the USB.SYS Driver to function, and you should be able to reinstall Windows, if last known good configuration doesn't work, i hope this helps, please give good rating
Apr 30, 2009 | Computers & Internet
BAD_POOL_CALLER
Try a Repair Install with your WinXP Bootable CD. If Repair option fails you will have to do a Clean Reinstall of WinXP as a last resort.
Some details:
1. Boot with your WinXP CD
2.At the "Welcome To Setup" screen, Choose the option:
To setup Windows XP now, press ENTER. DO NOT choose !!!! To repair a Windows XP installation using Recovery Console, press R. IGNORE
To quit Setup without installing Windows XP, press F3
3. Accept the License Agreement and Windows will search for existing Windows installations. 4.Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, under the Circumstances you are in the next option will be Clean install
5. I this does not work it might be your memory --download and burn to cd memtest (http://www.memtest86.com/) and test your memory for errors.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
ASUS P5RD1-VM Motherboard Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
