Loaded with clothes and water, wouldn't start washing and started smoking.We unplugged it removed the clothes and waited until the next day ,turned it to the spin cycle plugged it in to release water.Smelled smoke but didn't see any.
  • Dan Webster
    Dan Webster May 11, 2010
    model number? Make?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to
put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on May 01, 2010
Wfw9050xw00
You should check the hot/cold water from wall to the inlet of washing machine, make sure it all are corrected. I came across the case that those hose were reversed from the first installation but the owner was never use hot water until the next owner faced the issue. Else, the control board need replaced.
Oct 05, 2013 | Whirlpool WFW9050X Washer
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Water starts to accumulate in the machine a few days after use.
sounds like you have a faulty hot or cold water valve need to replace faulty item until then just turn of your water taps after you have finished washing turn back on when you need to use.
Mar 29, 2009 | LG WM0642H Front Load
After washing cylce complete; 3-4 inches of water is left
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Washer does not spin or agitate when washing, but it spins when drying on cycle...
Hi Mate,
Check the controller, is it digital or analogue ( pushbutton or control knob that turns ) Sounds like part of the switching cycle has burnt out replacement of controler may be the answer
Stoker
May 11, 2008 | Frigidaire GLWS1233A Top Load Washer
PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Mar 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
