Question about Kenmore 24032\24036 Top Load Washer
My Kenmore Elite He washer is only 4 years old, it's motherboard has already been replaced about 2 years ago and now it powers on you set a cycle and the lid does not lock. Push stop (like to add clothes) the lid then engages and locks but I get a humming noise and it will not start the cycle. What do you think is wrong?
  • 1,998 Answers
Faulty lid switch I have had to work on a couple of these inside the machine there should be a technicans sheet so that you can do a diagostic test of the machine which will give you an error code dont be surprised with this unit if when you fix one thing that it gives you another code. I think the last one i worked on i had to replace motor harness lid switch and main control board before it stopped giving me error codes hope this helps
Posted on May 01, 2010
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
What does the code f17 mean? I've had it happen twice, according to the mannual, I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore...
F7
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Generally if everything checks good, you'll want to replace the MCU because it's not reading the motor correctly.
Mar 19, 2010 | Kenmore Elite 45986 Front Load Washer
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
