SOURCE: Dishwasher is not cleaning dishes.
you need to check to see what the temps of you water going into the unit is. it needs to be atleast 120 degrees. if not your unit may be waiting to heat the water, until it does then it wont go into the next cycle. it could be the heat cycle is not working so that would cause the unit to not advance.
let the unit run thru the place you think its stopping, but not more then 2 hours. if its not advancing then you might have a bad heating element.
SOURCE: Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
SOURCE: bfdw 650s blanco dishwasher leaks waterout the front
Hi, n
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
SOURCE: My Frigidaire Dishwasher FDB1050RES2 gets
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Hi I have a blanco BFDW 670s which is 5 years old and when i turn it on to start a cycle it sounds like it's working but wont bring water into the dishwasher then it stops after only after a couple of minutes. Had a a repair man out and he said there is a large plastic moulded part on th left hand side of the dishwasher which senses if the dishwasher is full of water. Appartently it's clogged up and to replace it with labour will cost $400. all the hoses have been checked and are clear
BLANCO BFDW 650 S sounds like it is working, but doesn't fill, spray arms dont rotate. anyone know the answer?
I have a blanco BFDW 65OS dishwasher and it isnt draining ,BARB
i would check the breaker first then the wireing then the micro switch the switches are located on the door latch under the control panel no the sink stop-ed up wouldn't cause this it would still run but not drain
