Question about GE WPGT9360EPL Top Load Washer
I have the same problem. The washer will not drain. I have taken apart all the connections to the pump. The impeller will go on for a few seconds then shutes down. There is nothing in those hoses and the pump moves freely. Is there a way to remove the drum to see if anything is in between the inner drum and the outter drum that is causing the water not to flow.
  • GE Master
  • 8,220 Answers
Posted on May 01, 2010
Water will not drain from bottom of dishwasher.
Possible that the drain pump/valve is faulty or is clogged. It is best to check the voltage on the pump/valve of the washer , if absent the program controller must be checked., if present with no drain then the pump/valve is clogged /failed and must be taken out to be cleaned or replaced.
May 17, 2011 | Dishwashers
Water not draining even after clean
The dishwasher has an outlet pump in line with the outlet hose. This pump must work in order for the washer to drain. The pump can be tested by unpluging it and removing the 2 hose clamps. Connect the pump to the mains for a few seconds and it should spin the impeler. The impeler must rotate a a speed and must not be obstructed in any way. If this does not spin the outlet motor it should be replaced.
Jan 20, 2010 | AEG 24 in. Favorit 40650 Free-Standing...
Whirlpool washer agitates, but won't drain water
HI, any resistance when turning the impeller in this case will confirm pump failure. these motor should have very slight resistance when manually rotated. the unit will not initiate a full cycle if the pump is defective. replace the pump asap.
Jul 24, 2009 | Whirlpool AWM5145/2 Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
We have taken apart the bottom of the dishwasher to be sure no food was clogging the exit. It is clear but the water still willnot drain
HI In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 13, 2008 | Dishwashers
F2 code
go back to drain pump.. pull pump out ckd the impeller on motor pump shaft there should be a slight resistance when the impeller is turned by hand ..have seen impeller come loose of motor shaft and free wheel
Aug 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer
remove bottom panel pump is slightly right of center in white housing the is a knob turn counter clockwise ckd for anything that may be blocking pump or has pump impeller locked be sure to ck as far as possible into pump throat if impeller is locked pump can be removed and taken apart just remove hoses and power plug take pump completely out and remove screws around edge reverse procedure when reinstalling just be sure large o ring is reinstalled properly
Jun 09, 2008 | Kenmore 45081 Front Load Washer / Dryer
Machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
Nov 06, 2007 | Whirlpool AWM5145/2 Front Load Washer
HOtpoint washer
check these
1)the drain hose is kinked
2)Does the lid switch click when closing?
3)Something in the pump or hoses? Check the hose coming down from the tub for socks, rags, etc.
4)Bad wigwag
5)Broken belt? Loose belt?
Also the pump would be the first culprit to check. I believe that the pump in this model is electric and not driven by a pulley, so switching out should be easy. First you want to verify that you have power going to the pump while in the drain cycle. If you have power going to it and it's not pumping water out you can be pretty sure that is the problem. The front panel can be removed by removing the two screws at the bottom and lifting out. Now you can get a good look at the motor and pump.
Oct 21, 2007 | Hotpoint VBXR1090D Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
381 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
