Question about Kenmore Dishwashers
My Kenmore 665.15962990 has just quit working. There is water in the bottom that did not drain. The panel is just dead, none of the digital spaces will respond to touch. The stock #FM0116750. Could you tell me how old it is?
    President:
  • 949 Answers
The model you have was built in January of 2002.
It sounds like the issue may either be power to the dishwasher has been lost, either a circuit breaker, fuse or switch in the home OR it may blown the internal thermal fuse. If you are handy I would be happy to walk you through how to check that.
Posted on May 01, 2010
I have a fairly new refrigerator that is leaking water into the bottom. It is coming from a ledge behind a panel that is attached with four screws behind the shelves. This has been going on for quite a...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | Kenmore Refrigerators
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
What is f21 on the kenmore he2
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you.
pls rate my suggestion....
Jun 24, 2009 | Kenmore HE2 Plus Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Sep 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
I have an older Kenmore refrigerator it is a Porcelain Plus 20 I believe. A couple weeks ago the ice maker quit working in the freezer. It is not a side by side. The arm is up on the icemaker in the...
sounds like you have 2 problems the arm being uop turns off the ice maker the water may be due to a clogged drain everytime it defrost the water should rund down the drain to the pan on the bottom and evaperate check the drain first
May 20, 2008 | Kenmore Refrigerators
Dishwashers Logo
219 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
