Question about Samsung LN-T3253H 32 in. LCD Television
Samsung LN-t375h - Shuts off after a few minutes
I have a Samsung LN-t375h that works fine aside from the fact that it shuts itself off after a few minutes. Any ideas on what this could be?
  • jcm1974 Nov 16, 2008
    I have the same problem with my LN-T3253H. It first happened shortly after I purchased the set. No problem there since it was still under warranty. Was told by the technical support people that they had changed the board altogether. Now it is happening again, but Samsung will not fix it because the set is no longer under warranty. Tough. This TV set was a disappointing purchase after all.
    Genius:
  • Samsung Master
  • 1,689 Answers
Sometimes components on the circuit boards can become thermo sensitive with age and use.
An experienced tech can troubleshoot for this, locate the defective components, and replace them. Under controled conditions, he will use a technique of using liquid air to cool, and a heat gun to heat.
The fault can be in the power supply, or any of the boards causing a change in the specs, thus causing the supply to go in to the protect mode.
Jerry G.
Posted on Apr 12, 2008
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
My Samsung LN-T4069F momentarily shuts off and restarts frequently. The shut down is very short. Is this a firmware issue?
No,this problems it is the tv Tuner signal board itself have issues.Tv intermittently shutdown and restart wright back and tv work fine as nothing wrong wright?Yes.This problems it is the tv Tuner signal board itself have ICS chips grounding issues problems.These ICS chips on the tv Tuner signal board are surfaces mounted soldering works and are not on sale indivitually ICS to the customers,even if they do,it impossible to do surfaces mounted ICS chips parts work without a 1200 degree celsius convaer belt style wave soldering machine any how.The tv still work fine wright,just used it.When it shutdown for good and don't restart it wright back again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 03, 2011 | Samsung LNT4069F TV
My samsung ln-t4671f 46'' tv is taking a few minutes to turn on,when it does come on it works fine.how can i fix this problem and how much will it cost? thanks..ROCMAN28
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Dec 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
I have a samsung ln-t375ha my screen blacked out but i still have backlighting and a on power light but no screen
The T-Con bd or the Main bd is bad. Have a tech check it out. There is no way to check these bds with a meter.
Apr 15, 2010 | Samsung LN-T375H 37 in. LCD Television
Worth It?
It would cost just around the same amount of what the LCD TV is worth. I would get another one.
Feb 22, 2009 | Samsung LN-T3253H 32 in. LCD Television
Tv switches itself off then back on again
It seems that the back light is malfunctioning or needs to be replaced the fact that it turns off after a few seconds indicates that is getting over heated. All LCDs, Plasmas and Projection TVs come with a shut off switch witch will turn of the monitor when a spike on the temperature is detected this is to protect the system from overheating. Now before you think about send it for repair; is it well ventilated? Does air circulates around it? Good luck!
Aug 27, 2007 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-T3253H 32 in. LCD Television Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
