Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
Lamp light on picture off
The kids were watching TV and the picture went off.  The double red lights flashing indicate bulb problem so I bought a new bulb.  Replaced bulb and still no picture and red lights are on.  I found this small fuse on the circuit board which looks black rather than being clear but thered is no info on it and Optoma says they don't sell it.  Any idea what size it might be and where to get on
  • 2 more comments
  • Anonymous Mar 28, 2008
    I can not get the Optoma RD50 to power up. Start up goes like this: Hit power button, green light blinks for long time, ultimately power indicator light turns red and also lamp indicator light goes red. I replaced the lamp a few days ago. Problem appeared to be solved after replacement, but now has reappeared.
  • tishynicole Sep 30, 2008
    I too have the same problem, replaced the bulb and the TV worked, then started doing the same thing again. Is unplugging it the only way to reset the internals? Or is there a manual way to do this?
  • harris1711 Mar 28, 2009
    hi my tv is optoma hdtv rd50 and getting two red lights w no picture or sound how can we resolve this?
    if i have the two red lights on and unlpugged it for 25sec. and still the same problem what else can be done?
  • 4 Answers
You might try unplugging the set for maybe 20 mins. to see if that might help in resetting the internals. Good luck!
Posted on May 14, 2008
SOURCE:
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Flashing Green Power on light not picture
Last Saturday evening, I experienced the exact same behavior on my Panasonic PT-52LCX65; it shut itself off without warning. I turned it back on, and it shut itself back off after about a minute, and the red "Lamp" LED on the TV began blinking.
I never got any warning message that the lamp was about to go out, but I've just replaced the lamp and now the TV is working just fine. We had to mail-order the new lamp, because neither H. H. Gregg (where I bought the TV on "Black Friday" 3 years ago), Fry's Electronics, nor Best Buy carries the part locally.
My wife found the new bulb WITH its holding apparatus for something like $120 online, roughly half what other sites were charging. We paid roughly $55 for UPS Next Day Air. The first bulb that was sent arrived broken (some UPS rep apparently thought "Fragile" meant "Shake and Drop"), but the company we ordered from cheerfully rushed us another one, and the second one was in much better shape. (Panasonic doesn't pack these replacement bulbs very well; there's a heavy bulb with a lot of air around it that Panasonic doesn't fill.)
More details available if anyone wants 'em. Hope this helps. -- ChuckE
Nov 03, 2008 | Panasonic PT-52LCX65 44" HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
190 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
