Question about Philips 42PF9631D 42 in. Plasma Television
Sometimes when changing channels it indicates "no input". Sometimes you can go to previous and then back and the channel will come up, other times, you need to power off and back on as the TV totally freezes up. Sounds strange but this happens alot when you go from the lower channels on the satellite box to higher channels or vice versa.
    Problem Solver:
  • 12 Answers
This actually sounds more like a signal issue on the cable box. When you go from regular digital chs to HD channels sometimes boxes will distort or pause the picture when changing channels (it's not the cable or satellite, it's your TV trying to read the different format of the chs) this is normal. Also, some TVs may need to have a firmware update and you can normally get it from the Manufacturer's website
Posted on Apr 30, 2010
Testimonial: "Thanks, I will call my satelite tech and see if Philips does have an update. Probably the situation as it does happen when switching between HD/non."
TV intermittently loses and regains audio/video from only a couple TV channels
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Sharp LC 46SV50U 46" LCD TV
A 16/4 channel Mackie VLZ bought new 1997 hardly used. Some times a channel goes quiet, sometimes the fault moves to another channel, or while setting a channel input signal the knob seems to work till...
I suspect you MAY have a severe ground loop. The green light indicates channel crossover if nothing plugged in.
MAKE SURE ALL connected equipment is powered from the SAME receptacle. If you service amps from receptacles at one end of the room and this board from the other end, you are ASKING for trouble.
Read up on "common mode" as it pertains to balanced lines. Equipment can be at risk if grounds "bounce" as they often do.
When green light with no inout shows up, slide all faders down first. Then unplug input lines one at a time... turn off the amps and then unplug the output lines one at a time. See if one of these inout or output lines was causing the green light.
You should be using BALANCED lines to your amps... either XLR or TRS types at both ends.
May 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
Channel 1 works fine but channel 2 doesnt put out anything. how can i fix it?
if you have indication of signal input for both channel you can go and reverse output cables of the speakers if the problem transfer to good channel change speaker cable-if you did not have input indication in the bad channel try to inverse input cable if it is cleared change your input cable if not you will have internal trouble and need service center to help.
Dec 14, 2009 | QSC MX1500A 2-Channel Amplifier
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Philips 42PF9631D 42 in. Plasma Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
