Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
The chain will not turn
The coil does not seem to line up which is creating friction and keeping the chain from turning
    President:
  • 2,220 Answers
Hi Justin;
Remove the chain from the bar install it on the clutch drive sprocket first (fairly tight against the drum) then install it on the bar top , nose, bottom. I think it is to far inboard. The OM is not clear on this. If it still is giving your trouble post back below and I will try to find an illustration.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 01, 2010
  • dontbother10
    dontbother10 May 01, 2010
    Brake band? Like this.
    A crescent wrench or pliers are often helpful. Lock the cover iv a vise or to a work surface. It requires to much force to try and hold the cover.
Why does saw die after running for a few minutes.
Well, if it is you lucky day it is a plugged vent to the fuel tank!! Loosen the fuel tank cap and see if unit will continue to run with out a problem. If the vent is plugged after a few minutes as the fuel leaves the tank a vacuum is created and prevents the fuel from entering the carburetor.
chainsaw fuel tank vent line repair
If not so lucky it can be the ignition coil that fails when it gets hot!
Chainsaw Ignition Coil Test
One other possibility is that the chain gets tight on the bar when hot. Check tension and oilier. Manually oil just to check it out.
Last item can be fuel/oil mix!! If confusion or what ever has no oil in the mix the piston gets tight against the cylinder creating excessive friction stalling the engine and potential engine damage!!
Feb 27, 2016 | Garden
What would cause my hydraulics to keep heating up on a 648g3 skidder?
Friction is usually the cause of hydraulic overheating. Every time the hydraulic oil moves through the system the moving of the hydraulic fluid against the hoses,pumps, cylinders , etc. creates friction. Any restrictions such as valves or filters can be hot spots because of the friction created as the passages get smaller the fluid moves faster creating more friction. Friction = Heat.
I would check the filters to make sure they are clean. Check the valves to make sure they are opening fully. Check hoses for any kinks or pinched spots.Try to operate the skidder at the lowest r.p.m. need for the work being done. Over revving can also cause heat buildup.
Hope this helps.
Bob
Dec 16, 2014 | Cars & Trucks
Replaced timing chain now won't start. seems like theres no compression
did you use the locking kit to lock the engine in place so the timing marking were in the right place. if you don't use the timing kit you can some times just be a mil off and have no compression so no start. you can make a tool to lock the engine in place. now if you did not use one its going to be a bit harder to get the timing right again. you need to get the timing chain off and line the cogs back up to the timing markings on the engine and you any tool that will keep them in place while trying to put the chain back on. then turn the engine over by hand and make sure they line up on 2 full turns and marking/s out you will need to restart it again with the chain off until it lines back up in place, when you think its right then put the engine back together make sure the plugs are out while doing this job as any compression will keep knocking out the timing while you are trying to set it up.
Mar 18, 2014 | 2004 Saturn ION
When I start to peddle the gear shifter moves as if im shifting gears and the chain comes off. Any suggestions?
I'm assuming you have levers on your shifter. If so, typically, the problem is the screw on the side has come loose allowing the lever to move. Tighten the screw a little see if it resolves your problem. If not snug it up some more. The tension of the screw creates the friction to keep the lever from moving.
Jan 04, 2013 | Trek 3500
Black arms in clutch dont allways come out and catch when rope pulled. Chainsaw rope pulls out without catching and turning over to start. What should i do?
Most Stihl starters that i have seen rely on the r clip securing the pulley on being a tight fit on the shaft, this creates a friction, as the pulley turns the clip trys to stay still and in turn pushes the pawls out, remove the clip and squash it close together to create a better fit on the shaft
Jul 09, 2011 | Stihl Chainsaw 045 056 Clutch Chain Saw...
2000 ford focus I have to keep replacing the coil pk. also I have heat when I am driving but none when sitting. already replaced the therm. and flushed it, replaced lower hose to rad. what is causing...
motorcraft parts are recomended, though after market high end coils would also work, accel,MSD and such, when you replace are you getting them with a new resistor, as this can cause packs to blow also.
as for your heat not blowing check the water pump, sounds as though it may have broken free from drive internally and only when high rpm is creating enough friction to turn the internal fan.
Dec 22, 2010 | 2000 Ford Focus
I have a poulan woodshark p 3314wsa it starts and runs, but chain doesn't turn
Does the chainsaw seem to rev up without any resistance, or does it bog down as you push the throttle? If it revs up quickly, then it sounds like the clutch plates may be frozen - usually due to rust. If it boggs down, then the chain and/or clutch housing are frozen or stuck somewhere.
The chain drive uses a centrifugal dry friction clutch with two weighted plates that are spring loaded. The springs keep the plates disengaged from the clutch housing to allow the engine to spin freely at an idle (or slip when the chain slows down due to the blade binding).
When you press the throttle, the engine revs up and the higher RPMs create centrifugal force causing the clutch plates to push outward - fighting against the springs, and begin creating friction on the inside of the clutch housing. If rust prevents the clutch plates from moving out to cause the necessary friction, the clutch housing (and drive gear which is permanently affixed to the housing) won't spin and the chain won't move.
With the engine OFF and cool...first take a thick towel or rag and place it over the chain with the engine switch in the OFF position. Try to move the chain in the normal rotation (top forward, bottom backward) to see if the chain moves freely or if it is stuck in position. If it does move, then take off the chain cover and then get a can of PB Blaster and spray the clutch plates and springs. Give it an hour or so and then take a rag and wipe off the excess and reassemble and try it. The excess PB Blaster will burn off with the heat of the clutch and the rust will no longer be a problem.
If the chain won't move, then somewhere along the drive the chain or clutch housing are stuck. Look for a bend or kink in the bar where the chain rides.
May 29, 2010 | Garden
The blade came off today and I put it back on but the blade doesn't turn. The section underneath the cover doesn't turn. Not sure what the problem is.
The clutch resides there and is responsible for coupling the engine crankshaft to the chain sprocket which is mounted to the clutch outer drum. When the engine speeds up, the inner clutch shoes are thrown out to the inner surface of the outer drum, thus coupling the engine to the chain. If the drum won't turn, it can be caused by excessive oil within the clutch which prevents the necessary friction between the shoes and the drum. Wash out the clutch interior with spray carburetor cleaner (from an auto parts supply house), allow to dry, then reassemble the bar and chain. Tighten the bar clamp nuts finger tight, and adjust the chain until it does not droop from the lower bar edge, but you can still turn the chain by hand. Tighten the bar fasteners and recheck the chain. Make sure the chain is properly sharpened and that the chain teeth cut toward you on the bottom run. Start the engine and run the tip near a piece of cardboard for several moments--it should throw off a thin line of oil on to the cardboard. Hope this helps!
May 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have been trying to turn it on but the pulley is too hard
The chain brake isn't engaged until engine speed picks up. The nice smooth bore the piston moves up and down in isn't smooth any longer. That is where the additional friction is being created.
Lou
Oct 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Vitamaster excercise bike makes clunking noise when in use,
The moving parts like chain sprocket,etc where the friction is lkely to be created is the exact place you have to oil. Dont apply more oil than needed. Avoid oil to parts like brake shoe,etc where friction is neccessary for those parts to work properly.
Aug 19, 2009 | Cycling
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
155 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
