Question about Dell Inspiron 8600 Notebook
Crash and Burn dell inspiron 8600 Help
Dell inspiron 8600 hard drive or registry?
error messages: A disk error occured Press Ctrl,Alt Del... loading PBR for descriptor2,PartMgr.sys_address F88804Ab base at F8887E000 Data stamp 00000000,Page_fault_in_nonpaged_area,Unmountable Boot Volume, *** Stop:0x0000000 ()x82F83030, oxoooooooED,oxoooooooo,oxoooooooo, StopCoooo21a Unknown hard drive error, And last but not least windowssystem32configsystem. Have tried to fixboot, load windows ect. Any suggestions
Thanks in advance
Bob
  • 1 more comment
  • mcwilliam Jun 29, 2008
    hav same problem as bob
    toshiba a50 satellite
  • gaylelsmail Nov 14, 2008
    I have had the same problem to the point that I will never buy another Dell product, ever. Any solution is welcome!
    -Gayle
  • Anonymous Mar 28, 2014
    recovery dic
  • 70 Answers
If I were you I'd run some hardware tests. Get testing software from your HDD manufacturer and download & run Memtest - http://www.memtest.org/
Let us know what you get :)
Posted on Nov 14, 2008
My computer when start I saw the logo of windows, but faster the screen its turned black and dont nothing. I reboot all componet and give me a msg fan are RMP=0, and the hard disk do nothing too.
Posted on Jun 22, 2008
  • 655 Answers
If you have backup of all your important files / data, i suggest you the restore factory settings. this will make your system as it was first time out of box.
to learn how you can do this click here:
thanks
iqbal
Posted on Mar 25, 2008
  • 4,234 Answers
Believe it or not, this sounds like a memory problem. Anytime you see an error of a page fault in a non-paged area, teh first thing to look for is memory issues. Can you move the memory stick(s) around? Try that first. Microsoft does not handle memory errors in certain areas very well. Sometimes moving the physical sticks around can place the bad memory cell into a less critical area that can be handled better.
Dan
SOURCE:
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
I have a Dell mini netbook Inspiron 910 when I turn the pc on it says a disk read error occurred press ctrl+Alt+Del to restart when I do that the same thing keeps coming up what do I do ???? Please help
It sounds like your hard drive has failed.
Make sure that you have removed all removable media like diskettes, CD, DVD, or flash drives from the machine to confirm. If after removing these items you continue to receive this error, then most likely the hard drive has failed.
Take the notebook in to a service center to have the hard drive replaced and the operating system installed.
Hopefully you have a backup of your data, since it is all most likely lost.
Dec 26, 2010 | Dell Inspiron 1000 Notebook
Dell mini inspiron 910. On boot " a disk read error occurred press CTRL+ALT+DEL to restart " when I do that the same message appears please help me.
I think you have a hard disk error.
Use your recovery disk, or better still Windows Installation disc, and start the boot up using the menu to select "repair system". That will save you the trouble of having to reinstall all of your software and settings.
If it won't work, a format of drive C will fix your errors but you will have to restore all of your dadt.
Hope this helps.
Oct 25, 2010 | HP Mini 1000 Netbook
As soon as computer is turned on the message bootmgr is missing press ctrl alt del to restart
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
i strongly suggest formatting your hard disk drive, and reinstalling the recovery CDs
if you dont have them, get Dell to send them to you -- it will cost you money
Oct 16, 2010 | Dell Inspiron 1545 Notebook
This is the error message that I receive when I turn on my Dell Inspiron 910: A disk read error occurred, press Ctrl Alt Del to restart. When I follow those directions, I continue to get the same error...
Hi
Thank you for your query
It would seem from your error message that your hard drive has failed
Do you hear any type of clicking noise coming from your laptop?
Please book into a reputable PC repair shop for repair
Regards
Shauqat
Sep 29, 2010 | Dell Inspiron 9100 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
This is the error message that I receive when I turn on my Dell Inspiron 9100: A disk read error occurred, press Ctrl + Alt + Del to restart. When I follow those directions, I continue to get the same...
hi there, a disk read error doesn't sound like a CD drive to me. It sounds like a hard drive failure to me. My advice is to take out the hard disk and take it to a person that knows about hard drives.
Jan 20, 2010 | Computers & Internet
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
Not going in window xp
You will have to try and boot from the Operating System CD and Run a Check Disk
from the repair utility chkdsk /r/f/p or try a factory restore on boot Press and hold: Control key + F11
Nov 17, 2008 | Dell Computers & Internet
Dell Inspiron 8600 Notebook Logo
645 people viewed this question
Ekse
Clive
Clive
