Question about Abit KN8 SLi Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
  • 3 Answers
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Posted on May 01, 2010
2 Suggested Answers
sd03
  • 59 Answers
SOURCE: What is the fastest CPU Ican run ain an Abit KN8
The fastest cpu is quad core and dual core
Posted on May 11, 2010
My motherboard does not accept my RAM upgrade. 4 Go ( 4 * 1 Go). Compatibility is OK, i works with 2 Go. With 4 Go : i can't boot, continous beeps ! My BIOS is the most recent. What can i do...
Hi, you can see the specifications here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KN8+Ultra&fMTYPE=Socket+939
Try to download a manual.
My guess is that your cpu does not support that amount of ram.
The ram must also be at an equal size.
Your operating system must be a 64 bit to handle
more than 3 gb of ram.
Aug 27, 2011 | Abit KN8 Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=KN8+Ultra&pSOCKET_TYPE=Socket%20939
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
No boot
if you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Feb 07, 2009 | Abit KN8 SLi Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit kn8 sli motherboard won t boot up
PULL OUT THE WIRE FOR A POWER SWITCH ON THE BOARD AND TRY TO SHORT BOTH PINS WITH A SCREWDRIVER
Oct 17, 2008 | Abit KN8 SLi Motherboard
Help
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
Abit KN8 SLi Motherboard Logo
301 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
