Question about Sony Cyber-shot DSC-W170 Digital Camera
When i turn my camera on the lens goes in and out and when its done it says 'turn camera off and on again' what is wrong with my camera
    Novelist:
    Sniper:
  • 85 Answers
The message "turn the power off and on again" actually indicates that there is a mulfunction w/lens. you can try initializing the camera.make sure your using a fully charged batt. (home>settings>main settings>main settings1>initialize).if it still doesnt work, try power reset procedure (turn power off,remove batt, and leave cam w/o power for more than a min.) if still issue persist your camera might require repair or you can go this unconventional route:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/dsc-w50_acess.turn_off_on_again
...so banging the camera may actually work some times.but be careful doing this might cause injury or hardware damage...but what have you got to loose anyway. hope this works for you.tnx:)
Posted on May 01, 2010
Testimonial: "it did not work, but thanks for you time and advice!"
Sanyo S770 lens won't retract on shut off and shuts down when try to zoom and get lens error
Lens error happens during the lens guide pin wrong movement. Please try these below and let me know.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 06, 2011 | Sanyo Xacti VPC-S770 Digital Camera
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
Sep 21, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My pentax optio 50 lens got stuck half-way and now the camera turns on briefly and then goes off automatically. I've replaced batteries and pushed the lens in manually, but it's still not working. Mary
This is tricky .. if you have no warranty, and have already managed to push the lens in.. I suggest pulling the lens outwards gently AS you simulataneously turn the camera on. You may be able to use a small suction-cup affixed to the lens to do this :)
you could hold the lens-cover open with tape so the cover is less likely to be damaged.. good luck, this problem is common, annoying, and usually not worth repairing (*although with some cameras it can be done again and again!)
Aug 30, 2009 | Pentax Optio 50 Digital Camera
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
Lens error. lens comes out than back in turns off than on and goes back in and out than says lens error. this camera is only about 8 months old. i have a feeling if it were to get repaired some else will...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 19, 2009 | Nikon Coolpix S210 Digital Camera
Turn of and try again
you camera goes in a stand by mode you need to use a memory card nothing is wrong with the camera. So I would suggest you must use a memory card reader for this purpose.
Jan 20, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Casio Exilim EX-S880 won't turn on, lens clicks
Do you have a mem card installed? If so what size? Make sure it is the right size for your camera. Also make sure the battery is fully charged. The lens clicking twice makes me believe that there was some kind of damage done to the lens like maybe accident powering on when it wasn't supposed to like in a pocket or something. You may have to send it in. Expecially if it says "lens error".
Jun 28, 2008 | Casio Exilim EX-Z55 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
566 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
