Question about Nokia 6233 Cellular Phone
Says an enhancement is connected when it is not!
My Nokia 6233 has suddnely displayed the headset symbol when I have no enhancements connected. Obviously when someone calls I cannot hear them talk. What can I do to fix this ... I have turned the phone off and on and removed the battery but to no avail ... help!
  • 1 more comment
  • snake1967 Apr 07, 2008
    nokia6233 shows that i have a headset attached when i do not !
    i have restored factory settings, connected then disconnected headset, battery out etc but it still registers that a headset is connected.
    Any ideas ?
  • Djreadie Apr 12, 2008
    My mobile also displays the headset when nothing is connected and so cannot hear anyone on it.
  • razzaq abdullah shah May 12, 2013
    nokia 6233 reset factory settings code i forget cod
    President:
  • 1,017 Answers
Try to Restore factory settings
To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett..
Enter the security code.
The default security code for Nokia is 12345
Posted on Mar 29, 2008
  • jimfarquhars Aug 26, 2011
    I solved this by downloading and installing Nokia Software Updater....then use the option to REINSTALL software via your pc :)
SOURCE:
My nokia n 73 phone is howing enhancement symbol on the right corner of the screen even if no enhancement is connected and when i make or receive calls, i am not able to hear the other persons voice and...
try to clean the headset interface at the bottom,might the socket is corruded and lead inoto shortage...
if that symbol never removes.you can never hear incoming calls or even the person calling might not here you...
if doesn't work,bring it to a mobile srvice shop near you. might a hardware (board) problem.
hope it helps....
Jun 04, 2011 | Nokia N73 Cellular Phone
My Nokia 6233 has suddnely displayed the headset symbol when I have no enhancements connected. Obviously when someone calls I cannot hear them talk. What can I do to fix this ... I have turned the phone...
Just follow the steps
Make a backup of contacts in your another sim.
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Nokia 6233 Cellular Phone
6070 Headset symbol issue i have a Nokia 6070 and
If you still have the headset, connect it to the headset connector and remove it, do this several times and check everytime you disconnect it. If this doesn't help, please check if there's any short on the headset interface. Clean it with a soft cloth or cotton dipped in alcohol or spirit.
Your last option is to open it apart and check the headset interface internally. I would recommend you to visit a mobile repairing shop and get it repaired.
Good luck..
Thanks for using FixYa.
Jun 20, 2010 | Nokia 6070 Cellular Phone
I have Nokia 6233 and it's Headset symbol is displaying on the screen even no headset is connected. It was accidentally turned on. I am able to talk while incoming and outgoing calls only when...
you got a chort cut in the microfone contact,
phone indicates that the headset has been plugged in,and cut of the circuit to the phones microfone.
1)open your phone and clean the microfone connectors and the goldplated surface on the mainboard.
2)if your phone has been very wet, the short cut can be in the microfone.( change microfone)
If solution 1) doesnt help,
try solution 2) and change microfone.
This kind off problem is an common microfone issue.
Hope this helped, Please vote!
May 03, 2010 | Nokia 6233 Cellular Phone
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
Feb 25, 2009 | Nokia N70 Cellular Phone
Enhancement problem
firstof all,,, are you a cellphone technician?if yes just check first the connection in the head set area! use a tester if the connections are ok!
Sep 02, 2008 | Nokia 6233 Cellular Phone
Headphone symbol
hi,
please contact nokia service centre for further assistance because the headphone symbol reveals that a headphone is connected which should not appear as you say..so please take your mobile to nokia care for service..thank you!!..
Jun 23, 2008 | Nokia 3120 Cellular Phone
Nokia 6233 Cellular Phone Logo
322 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
