Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Ice maker not filling up with enough water - Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
    Guru:
  • 1,524 Answers
Remove White plastic cover. On right front side you will see an adjustment screw with + and - .Turn only 1/4/turn at a time.
Posted on Apr 30, 2010
Why is my ice maker is not making ice
Sounds like its not getting enough water to the ice maker tray during each cycle. Possible restricted water fill line, plugged water filter or low water pressure to the ice maker.
Oct 08, 2014 | Frigidaire Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Water is not filling ice cube maker
Is the freezer cold enough? Should be close to 10 degrees.
Once the ice mold has water in it, it may start cycling when it freezes.
If the fill tube is blocked with ice, the water inlet valve is leaking and needs to be replaced.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not fill with water and will not make ice .
you have a bad water valve easy repair located in back left of fridge
pull fridge out slowly see if you have enough line
Apr 17, 2009 | Refrigerators
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water to my ice maker freezes in metal tube
ON MOST ICE MAKERS, THERE IS A LARGE WHITE GEAR ON THE FRONT OF THE ICE MAKER BEHIND THE COVER.
THIS GEAR HAS CIRCUIT TRACES ON IT THAT WILL BURN THE PLASTIC FROM ARCING FUSING THE WATER FILL CIRCUIT TO ANOTHER ONE CLOSE TO IT. THIS WILL CAUSE THE FILL TIME TO TRIPLE FROM THE 7 SECONDS TO ABOUT 20 SECONDS. THIS WILL OVER FILL THE ICE MAKER AND POUR DOWN INTO THE ICE BIN. THE ONLY SOLUTION IS TO REPLACE THE CONTROL MODULE OR THE ENTIRE ICE MAKER.
Feb 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
138 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
