Question about Sewing Machines
The machine turns but slowly - Sewing Machines
    Genius:
  • 1,116 Answers
It could be the machine needs to be cleaned and lubricated.
It could be the motor needs to be repaired or replaced.
It could be the power pedal needs to be repaired or replaced.
Refer to the maintenance section of the manual for your machine for cleaning and lubricating.
The rest has to be seen live for trouble-shooting.
Take to your sewing machine dealer for an evaluation.
Posted on May 01, 2010
My machine is running very slowly and the wheel is very hard to turn by hand
If it's an older mechanical machine, how long since its last clean and thorough lube? The machine is probably seizing due to old oil that has turned gummy. Stop using the machine until it is addressed as the motor could suffer damage trying to run a machine that is stuck.
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Oct 28, 2017 | Sewing Machines
I found out my machine is low shank. Can I use the low shank roller presser foot #151 on my Singer 20U53 machine?
I'd put them side by side and if everything matches up then I'd think you would be able to use it. Place it on the shank and very slowly turn the handwheel to make sure the needle doesn't hit. If all looks ok then I'd make a few stitches, again very slowly.
Apr 07, 2016 | Singer Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
My sewing machine will not pick up the bobbin thread
double check the timing. The hook must pick up the loop in the needle thread as it starts on its up stroke.
Remove bobbin cover, needle plate etc to expose hook. Turn hand wheel slowly towards you until needle reaches its very lowest point
then continue to turn very slowly until needle comes up about 3/16" in this position the tip of the hook should be exactly behind the needle and just above its eye
Feb 28, 2014 | Sewing Machines
Singer stylist 533 timing
1st time feed dogs to raise and lower in time with the needle bar going up and down. Fit needle and slowly turn balance wheel towards you until needle is at lowest point, note where hook point is. Turn balance wheel towards you very slowly and stop when needle has risen about 3/16" from it lowest point. The hook should be immediately behind the needle and slightly above the eye.
Feb 13, 2014 | Sewing Machines
Singer 9113 - The machine slowly stops
have you checked the connection of the power cord to the machine?
have you checked the connection of the pedal cord to the machine?
if these are securely connected, then you may need a new foot pedal
Mar 28, 2012 | Sewing Machines
Wheel turns very slowly does not speed up when
Try oiling all the moving parts with WD40, old oil on the machine may have congealed, make sure there is no thread stuck in the raceway.
Oct 19, 2009 | Singer Sewing Machines
LS 2125i haveing problems getting the top thread
I don't know about now, but in the old days you had to pull out about three inches of thread through the eye of the needle & hold it with plenty of slack while turning the wheel on the end of the machine slowly. Once the needle disappeared below the plate & then reappeared you could stop turning the wheel & slowly pull on the end of the thread you are holding to pull the thread from the bobbin up. Of course there must be thread on the bobbin spool & it must be some extra hanging out. (not broken off flush with the spool)
Jun 30, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
