Question about Acer Aspire 1414 Notebook
How to restore an Acer 1414 to factory settings, I have the discs, but just says hard drive is ok but still have same stuff as I always have. Any solutions/
    Sniper:
  • 57 Answers
When you insert the (WINDOWS) disk, restart the computer and make sure you boot from the CD or DVD, not the hard drive. After it installs and asks if you agree with licensing, you should see 2 options for installing windows. Usually the 1st option says (RECOMMENDED) but in order for a 'clean' install you'll need to check the 2nd box that says ADVANCED. This is the option that allows you to actually restore it back to the way it was. The hard drive will have to be formatted which will clean out your files *** MAKE SURE THAT IS WHAT YOU REALLY WANT*** Those files will be gone for good. I also recommend getting on Youtube and search 'HOW TO FORMAT AND DO A CLEAN INSTALL OF WINDOWS' There are several excellent tutorials that will walk you right through it. It makes it easier if you can actually see what steps they are taking on their computer. I hope this helps! Good luck!
Posted on Apr 30, 2010
Testimonial: "Thank you the solution was fantastic, thak you again for all your help it will saved on pulled out hair!"
  • Matt M
    Matt M May 01, 2010
    You're more than welcome and I'm just glad I could help. If you run into any more problems, just reply to this post and I will help with anything I can. Thank you so much for the wonderful feedback!
    -Matt
Reset acer
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to Start > Restart to reboot your netbook.
Hold down Alt and F10 when you see the Acer logo on the screen.
The recovery menu will load.
Hit Enter and then Next to see your recovery options.
Choose Factory Restore to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
or
When a vital file becomes corrupted, it might be necessary to restore a computer to its original factory settings.
This process also cleans up the hard drive and removes old programs that can make a computer slow and unresponsive.
But, because restoration wipes away all files you have installed or created, it should be a last-ditch effort in trying to repair a computer.
If you have reached this point with your Acer laptop or desktop, the manufacturer provides a utility to restore the factory settings.
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Click All Programs, then the Acer folder.
Select Acer eRecovery Management to open the utility.
If a Windows prompt asks for permission to run the program, click Yes.
Click the Restore button in the pane on the left side of the program window.
Click Completely Restore System to Factory Defaults.
Select the Yes option in the dialog box that asks you to confirm the action, and click Start.
Click OK in the second confirmation dialog box to restart the computer.
Click Next in the warning window that appears after the computer reboots.
This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Click Next again in the Restore Destination window, and click OK in the popup that gives you one last warning about deleting your data.
The restoration process will begin.
Click OK when the utility lets you know that the restoration is complete.
The computer will restart, and Windows will finish the recovery process.
http://acer.custhelp.com/app/answers/detail/a_id/12869/kw/factory settings/related/1
May 01, 2013 | Acer Aspire V3-571G-9435 15.6-Inch Laptop
How to configuration hard drive to factory default
Step 1:
Which operating system ?
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Mar 16, 2013 | Acer Aspire 5500 5570-2609 Laptop
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
Acer netbook restor to factory settings
Normally for acer machine if you need to do factory restore.. You need to call acer were they will provide a restore disc with all the features that came along with the computer..They might charge you about $15.... So call acer etch support.. They are the best to help you on this
Sep 20, 2010 | Acer Aspire One Netbook 8.9" Notebook
How can i make factory setting for Aspire 5610 without recovery disc and/or with recovery disc
You do not have to make factory setting, infact you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10 (try both), it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Acer Aspire 5610 Notebook
Restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
Jul 15, 2010 | Acer Aspire 5050-3242 Notebook
My acer laptop needs restoing
To restore to factory setting, power up the laptop, when you see the logo, press both Alt and F10 key, it will initiate the recovery program. Follow the instruction on screen to restore to factory setting.
CompQ
May 11, 2010 | Acer Aspire One PC Notebook
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
How can i restore a acer aspire one d150
Hi , maybe this might work for your acer,
Go to acer recovery.This can be done by hitting Alt & F10 together as soon as the computer starts.
Hit hard disc recovery.
Follow the instructions and this will format the drive and reinstall the factory settings. hope this helps
Dec 03, 2009 | Acer Aspire One D150-1587 Netbook
Restore to factory setting
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
Nov 09, 2008 | Toshiba Satellite L25-S119 Notebook
Acer Aspire 1414 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
