Question about Hitachi 55HDS69 55 in. Plasma Television
My Hitachi plasma television is not working properly. With the exception of the power button, the side panel controls will not work. On the remote, the only controls that work are the power, volume, mute and previous channel buttons.
  • 10,865 Answers
Hello Ron. Your tv has more than one issue. If it is less than three years old consider a repair but get a couple of estimates and do take it into the shop as opposed to a costly house call. IF it is an older set, consider replacing it. The new sets are digital and under warranty. Joe
Posted on May 01, 2010
The picture on my lg tv has gone dark. Every button on the remote is working except the menu button.The button on the side for menu is not working either.
Check and repair the remote control. It sounds that it need cleaning. But lack of brightness to a Plasma screen might be to a faulty Z Sustain board. Check this for more details about the TV fualts, and to how to repair and clean a remote control.
Jan 05, 2013 | LG 42PX5D 42 in. Plasma HDTV
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Remote control no longer working
all universal remote manufactures provide you with a setup guide to use their remote control. follow the instructions carefully and you'll be sitting pretty.
Jan 21, 2009 | Hitachi 42HDS69 42 in. Plasma Television
TV power will turn on and off but no other buttons operate.
This is more than likely down to your main AV board, Open the back and look at the board that has the arial and scart sockets on it, Take the part number of it and Google or Ebay for a replacement.
This will solve your problem.
Hope this helps
Jan 08, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Dec 12, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
All of a sudden my TV remotes do not work properly
Since you said that the remote that originally came with the television does not work either, it's most likely a problem with the IR sensor in your television.
To make sure that something more important with the television did not fail, the next time this occurs, walk up to the television and attempt to manually change the options using its controls.
Nov 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Aug 13, 2008 | Hitachi 42HDT52 42 in. Plasma HDTV
Hitachi 55HDS69 55 in. Plasma Television Logo
274 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
