Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
  • joymaxwell May 01, 2010
    Brivis Model ME 20 E
    Brivis Heater ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Posted on Jul 16, 2010
Spanner through car yellow light symbol on solid
Not unusual to be one of those things. Cancel the code and if it returns, then is the time to investigate as it is not a serious fault.
Jul 27, 2017 | Cars & Trucks
Vaillant ecotec plus 824 problems
The Symbols should be there whenever the boiler is in use, it confirms the pump is running and the gas valve is open...i.e firing.
the pump overrun may come on after a firing to dissipate excess heat and is what it says, i.e the pump continues to run to keep the hot water moving to prevent the boiler from getting noisey. Sometimes you may see a radiator symbol which means the boiler is doing a 'heating' cycle as against hot water.
Nov 20, 2013 | Computers & Internet
I bought my Nuvi 200 in Thailand. I also bought an Australian card. How do I get the voice in English instead of Thai. Tom
  • Press TOOLS (the spanner symbol bottom right of the screen that shows WHERE TO and VIEW MAP) It might take a little trial and error if you don't speak Thai but it should be possible.
  • Press SETTINGS (The spanner symbol)
  • Press VOICE (The lips symbol)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
Press each in turn and change each to English.
Jun 04, 2011 | Garmin nuvi 200 Car GPS Receiver
Garmin 1490 LMT came from box with foreign language. How do I change it to English?
On the bottom right corner of the screen which has WHERE TO and VIEW MAP there's a spanner symbol.
  • Press the spanner symbol
  • This brings you to another screen. Press SETTINGS (the spanner symbol) of if it doesn't have a spanner symbol press LOCALE (the blue symbol)
  • Press LANGUAGE (The lips symbol)
  • This takes you to a screen with 3 items on it; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press VOICE and select an English speaking voice. Press TEXT LANGUAGE and select English or American English if you're in the USA.
This should solve your problem.
Jan 29, 2011 | Garmin nuvi 1490T GPS Receiver
I have a Daikin split system ducted aircon. temp on 22degrees.turns off error code flashes E5, and a picture of a spanner
E5 Outdoor activation of compressor over heatprotection or motor lock
Check condenser coil. If dust blocked-clean it.
Check out door fan motor is working. If not replace capacitor or motor.
Check compressor-gradually amps increasing-replace capacitor.
Check for gas pressure. No gas also gives over heat compressor.- Leak test and rectify.
Jan 16, 2011 | Heating & Cooling
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Re start problem
What is the Manufacture of the machine and the model number.
Without this information, there is no way to supply any suggestions.
Get back to me with those 2 items.
Thanks
Mac
Mar 28, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
1,381 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
