Question about Microsoft Windows Vista Ultimate Edition
Pen drive as ram
I heared by someone that i cam use my 4GB Pen Drive as ram to speed up my system in Vista Ultimate. Please tell me that how can i use my pen drive as ram. Also tell me even i use my 4GB pen drive as ram in Windows XP Pro.
My e-mail : rijaxxx@yahoo.com
  • rijaxxx Mar 25, 2008
  • 31 Answers
USB Flash Drives with ReadyBoost Feature are required to use the feature of Windows Vista. First U will need this and then just plug it in USB Port, Right Click on the Drive you will find a tab to configure the device as RAM.
Note : Tab appears on all USB Flash Drives but the feature is configurable only over readyboost enabled ones
Posted on Mar 25, 2008
  • Surinderpal Singh Mar 25, 2008
    Feature is just introduced in Vista.. n will not work with Windows XP or prior
    Sergeant:
    Champion:
  • 306 Answers
It will not work with xp or any other version of windows except vista, and it has to be a readyboot compatible flash drive to work.
Transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Jun 08, 2009 | Transcend (589307) Media
Very slow transfer to Kingston 8GB datatraveler
HI,
- Check if your PC is running at its maximum efficiency
- Close all side processes that are not of any use to you. This can be done by pressing :Ctrl+Shift+Esc and then going to processes. In there only close the processes that are under your user name and are of no use. NOTE: DON'T CLOSE "EXPLORER.EXE". This will free a sizeable amount of your RAM, making your PC generally faster.
- While copying anything, avoid multi-tasking as that will simply slow down your PC, causing a delay in the copying.
IF NONE OF THIS WORKS, then create a back-up of all the software in your Pen-Drive and then format it.
This should just about do it.
If still the problem persists, go to your dealer- your pen-drive must be in its warranty period.
Sep 30, 2008 | Electronics - Others
Tip
How to install vista from pendrive
Its very difficult to install windows vista if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows vista DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pen drive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows vista DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows vista DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Microsoft Windows Vista Ultimate Edition
Pen drive not detecting
If you have any other Computer with XP operating System. Connect the Drive. Check if detected then format the drive by checking full format on the menu.
Then connect it the Vista computer and Use it.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
I'm Having problem with Vista, not detecting Pen Drive
Unplug the pen drive before booting (newer laptops support booting from a USB drive, and they restore your "healthy restore point".
Format the Pen drive from Disk Management (right click on computer, choose manage, select Disk Management) to 32 bit fat, this leaves it compatible with Windows 98 SE, but the 16 Bit seems to give Vista fits. Good luck.
Jul 30, 2008 | Microsoft Windows Vista Ultimate Edition
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : safiqul.alam@gmail.com
Mar 25, 2008 | Electronics - Others
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Microsoft Windows Vista Ultimate Edition Logo
142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
