Question about Maytag MSD2756G Side by Side Refrigerator
Water is overflowing at the bottom of the freezer
Water is overflowing the pan under the coils at the bottom of the freezer. i took the panel off the back of the freezer and tryed to determine where the water is coming from but with the freezer door open everything is defrosting so everything is wet. when i first took the panel off i saw water hanging off the coils, but i know there is suppose to be some condensation coming off of them. the frig is still on and the water is still connected and on. i had to take the ice maker off in order to get all the panels off the back of the freezer, but the waterline for the water goes in the door at the bottom and seems to be fine. Where could this water be coming from and if this is normal, where is all this water suppose to go?
    Guru:
  • 1,524 Answers
Blocked drain line for when the freezer goes into defrost.
Posted on May 01, 2010
Kenmore Refrigerator by Whirlpool, model 106, top freezer. Water drips into refrigerator from freezer. I have de-iced the coils in the freezer, under a flat panel. I made sure that water flowed from the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Refrigerators
Every few days we have water under out fridge / ice making fridge took pannel off bottum of fridge in front there is small pan in there full of water why should this be doing that
Leo Ponder
imufo2
Sep 04, 2011 | KitchenAid Superba KSRG25FK Side by Side...
My refrigerator is leaving a puddle under the freezer - it is a side by side. There is not a drip pan in the bottom. Should there be a drip pan? What could be causing the puddle?
Leo Ponder
imufo2
Aug 16, 2011 | Hotpoint Refrigerators
Water is leaking out of my kenmore bottom freezer frig model 76253702. I want to empty the drain pan. Where do I find it? I Already took off the front grill but don't see the drain pan. And how should...
Leo Ponder
imufo2
Aug 15, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Have water coming from the freezer and dripping down in the lower section of the refer. Took out the pan and the light module-temperature dials and found a build up of ice on the bottom of the feezer...
Leo Ponder
imufo2
Aug 09, 2011 | RTO Refrigerators
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
Water pooling and freezing in bottom of freezer. I've shut the valve so no water is going to the ice maker but water still collects. I can't figure where the water is coming from. Can you help? Thanks!
Sounds like the drain from the freezer evaporator coil is plugged causing the condensate to overflow and fill the bottom of the freezer then refreeze. Most freezers have a drain line from the evaporator to the bottom of the refrigerator leading to a collection pan to allow evaporation of the condensate. You may be able to access the evap condensate pan by removing the rear panel of the freezer. I can not say for sure without the specific model of the unit in question.
Jun 23, 2009 | LG LFC25760 French Door Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Ice build up on bottom of freezer
For units with automatic defrosting, there is a drain, sometimes concealed, for the defrosted ice (water) to drain into a removable pan under the coils below the two compartments.
I suspect this is clogged with bits of debris and preventing the melt-water from dripping into the pan.
Check under your ref./freezer behind a trim grill for this pan and check the condition of it; overflowing or empty.
Normally, the fan that blows ambient air through the coils keeps this pan dry-to-moist.
It's fairly shallow so if your ice maker is leaking it will overflow but it should normally only be wet for a short time after the defrost cycle.
If it is pretty dry, note which side is wet. If it is wet under the freezer section, the clog might be loacted there.
If you do not see any holes that could be a drain in either side of the fridge, you could have a more serious problem trying to free it.
Each liner is made as one piece to help keep the inside free of dirt traps but there may be access panels and if they are found low and in the back, they may be intended to access a drain.
If you are lucky enough to find a hole toward the bottom, you should be able to free the drain.
Depending on the location for access, you should be careful poking anything too stiff (like a screwdriver) into it as the coils could be damaged.
Something like a piece of 18 gauge copper wire would be better.
Aug 31, 2008 | Maytag MSD2656G Side by Side Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
416 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
