Question about Sony Handycam HDR-HC7E DV Digital Camcorder
Blown Sony HDR-HC7E fuse or board?
I have a Sony Handycam HDR-HC7E camcorder. I used a cheap AC adaptor off ebay. It lasted about 5 minutes before the charger blew...and took my camcorder with it - a soft "phut" sound was heard!! No charged battery powers it on now.
Question : is there a fuse or a part inside I can change? Is there a common part which would blow in this situation? Where can I find a service manual?
Thanks in advance.
Dedee
  • 4,234 Answers
There are internal fuses yes, but they are surface mounted ones and not a DIY repair. There are protection diodes internally as well. If the adapter was not the correct one, it is possible that it popped the diodes and fuse.
You can buy the service manual from Sony directly for a cost.
Hope this helps,
Dan
Posted on Apr 30, 2010
Why when I use the inbuilt projector of the Sony Camcorder HDR-PJ240E with an external device,the projected screen becomes plain blue after a few minutes?
This maybe due to the external device not receiving signal to keep the display on the screen or a cable that isn't quite right. Many HD cables can cause this issue due to a security feature built into it to prevent streaming copies which helps prevent piracy. If you are using say an HDMI cable, try a different one.
Nov 26, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
The ac power adaptor ac-v515 is dead.
I can't find the AC v515 adapter any where! But You can buy the next best thing. A battery charger one that will at least fit an NP-F730 battery. Go on to eBay and type Sony vc1000 and anything related will come up. These chargers can be used in your car and at home, what's more they are not expensive.
Nick
May 02, 2012 | Sony Handycam DCR-VX1000 Mini DV Digital...
Hi I've connected a firewire cable between the handycam and my new iMac. iMovie/iMac doesn't recognise the connection. Are there settings on the Handycam that need to be made for transfer to the iMac?
No need to change any settings it will auto connected.Check your cable may be its faulty. Try other think to attached your iMC.If still not working then You Firwire driver not instal.
Oct 28, 2010 | Sony Handycam HDR-HC7E DV Digital...
Camera LCD screen
Perform the following troubleshooting steps and check whether it helps;
1. Check whether the issue persists with all the tapes. If the issue persists with a particular tape, the issue is with the tape. change the tape. 2. Check whether the battery is fully charged, 3. If the batteruy is nit fully charged, connect the Camcorder to the wall outlet using the supplied AC adaptor. 4. Then, reset the Camcorder by pressing the RESET button using a sharp-pojnted object while it is turned ON.
5. If the issue still persists, remove the battery pacjk and disconnect the Camcoredr from the wall outlet; then slide the power switch to ON position for at least 30 seconds. Then reconnect the AC adaptor to the Camcorer after 1 minute.
If the issue still persists, service may be requuired. Please cointact ur Camcorder manufacturer to get it serviced.
Oct 15, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Sony Handycam HDR-HC7E DV Digital Camcorder Logo
309 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
