Question about Frigidaire Refrigerator Light Switch - 5303289051
LIGHT DOES NOT WORK REPLACED BULB STILL DONT WORK
  • 565 Answers
Usually the switch is sticking when that happens. Look for a button or lever on the door frame where the door makes contact and push it in two or three times until the light comes ON.
Posted on May 01, 2010
1988 pathfinder no dash lights no revers lights no tail lights no gaiges
If they all stopped working at the same time then it is probably a fuse or possibly 2. Check your fuse panels in the dash and under the hood. The dash lights and gauges should be a fuse labeled instrument cluster or guages, it is probably blown. The other fuse to look for will be the tail light fuse. This is where I would begin.
Sep 23, 2010 | 1988 Nissan Pathfinder
Headlight not working
TRY ANOTHER LIGHT BULB.BUT DONT LET BARE HANDS TOUCH BULBS BECAUSETHEY ARE HALOGEN.OILS FROM YOUR FINGERS OR HAND WILL CAUSE THE BULB OVER HEAT AND BLOW.IF YOU TRY ANOTHER BULB AND STILL DONT PROBLEM COLUD BE BULB SOCKET CORRODED OR DAMAGE OR WORN BULB CONTACTS.LOOSE POOR GROUND WIRE OR SHORT IN WIRES TO BULB SOCKET.
Jul 12, 2010 | 2005 Chevrolet Impala
Head lights work, brake lights work, blinkers work, tail lights dont, replaced all fuses and bulbs
did you change any relays  swap some relays to see if you can get the tail lights working but something else will fail    do you mean marker lights  make sure you used the correct bulb type  many are dual filament bulbs and will not work right if you used single filament bulbs
Nov 03, 2009 | 1997 Honda Accord
Brake Lights and Hazard still dont work
TEST FRONT RIGHT BLINKER CIRCUIT AND REPLACE THE BULB,,WITH PROPER BULB...A DOUBLE CIRCUIT BULB IN A SINGLE SOCKET WILL DO THAT ALSO A SINGLE SOCKET BULB IN A DOUBLE SOCKET HOLDER....CHECK LEFT SIDE BULB FOR ACURANCY
Aug 29, 2009 | 1993 Chevrolet Astro
Low beam not work !!
replace the headlight bulbs. Usually when the bulbs blow out the low beam blows out first, but the high beams still work. If you want and need both low and high beams to work then replace the headlight bulbs with brand new ones and I garauntee that both low and high beams will work
Mar 27, 2009 | 1999 Dodge Caravan
Brake light dont work
check the fuse for the brake lights. The brake lights and siganl lights use the same bulb filament. The parking and running lights use a dimmer filament in the bulb. There are 2 filaments.
Your brake lights work through the multifunction switch which operates the signal lights. If the signal lights work, you may have a bad brake lamp switch which is on your brake pedal arm.
Let us know what you find.
Mar 20, 2009 | 1998 Lincoln Town Car
My run lights dont trun on
Check for a Burned out Bulb on these Lights. I had one of these in School and it Did this. Had a Bulb Blown. Replaced it and they Started Working Just Fine. Please Rate My Response! Thanks!
Feb 01, 2009 | 1984 Oldsmobile Cutlass
Tail lights dont work
Replace the bulbs.
The bulbs will have two seperate elements in it which is why the brake light works.
Take the bulbs out and you will see the seperate elements.
Jan 08, 2009 | 1995 Subaru Impreza
Interior light
No. If you see that the bulb was burned, you can replace it yourself, you dont need to take off the battery terminal since taking it off might cause more trouble to your car. dont worry you cant be electrocuted by a 12V dc by just replacing the bulb
Oct 20, 2008 | 2004 Toyota Corolla
Frigidaire Refrigerator Light Switch - 5303289051 Logo
443 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
