Question about Whirlpool GBS307PR Electric Single Oven
E1 f5 error code whirlpool gr399lxhs
The code came up initially when I tried to start the self clean cycle. The e1 f5 code has come up and the door latch will not unlock. At the suggestion of Whirlpool I have unplugged for at least 15 minutes, I left it for 30. I pushed and tried to wiggle the upper right corner of the door, I have tried the center of the door. Nothing has worked to unlock. Is there a location on the stove that I can access a switch to open the oven?
'Maryp
  • 1 more comment
  • Anonymous Mar 25, 2008
    e1 f5 will not unlock
  • khammann Nov 16, 2008
    anyone have a fix? i have left it off over night, no help. i have tried to bump/jar the door, no help.........
  • Anonymous Nov 28, 2008
    E1 F5 error code. Door won't unlock after running clean cycle. Is this a mechanical trouble with the door lock, or is this from heat sensitive electronics?
Will spam hahahahahaha iam so evil!!!!!!!!
SPAMSMMSMSMSMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMmmmmmm
mmmmmmmmmmmmmmm
m
mm
mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm}
Posted on Jun 20, 2012
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
Posted on Oct 01, 2010
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Trying to clean my whirlpool oven. when it start button, an E1 - F5 comes up. What is this telling me.
What the F5-E1 error code means is that the door lock asm. is not operating so when its suppused to close and lock the door to self clean it cant do it since something is wrong with the latch/lock assambly
Some of the things that would need to be checked to see why the latch isn't working are;
the latch position switch,the latch itself to be good and opening/closing, & the part called the soloniod that is what operates the latch so it could open or close
GENE
Sep 18, 2011 | Whirlpool Ovens
Cannot find my manual and would like to know how to use the self-cleaning part. I held the button down for "lock", but the door did not lock, and where do I go from there?
Give this a try:
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds. Momentarily (less than 5 sec.) press CANCEL key again to remove error code display. 2. Program and start the Clean mode. Observe to see if door locks. If it does not, inspect the locking mechanism from the solenoid to the latch pawl and door to find the cause of the problem. If the door is not locking, then 1 minute from the start of the Clean, the F5 E1 code will again be displayed. Press CANCEL key to remove error code display. 3. Once any mechanical problems with the latch mechanism have been corrected, program and start a Clean cycle (after, if necessary, clearing F5 E1 error code) to ensure proper operation of the door lock. Immediately cancel the Clean mode to observe proper operation of door unlock.
If this doesn't help try this link to locate the right model:
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Feb 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning cycle doesnt work. I keep getting an E1 F5 error. How do I get the self cleaning cycle o work?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$WR
Sep 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I am trying to run the self cleaning oven and keep getting a toubleshooting code of e1 f5. Not sure what this means or how to fix it/
Hello- The code you describe- E1 F5 - indicates a problem with the door switch. This little switch tends to fail during or after the 'self-clean' function is used. The switches are difficult to get to on some of these units so plan on just replacing it with a new one. This part is available locally at an appliance parts store with a complete model # from range tag. When power is re-connected, door motor should cycle back to correct position. Remember- techs call it 'self-destruct', so avoid 'self-clean'. The tried and true cleaning methods are a lot less destructive on the circuits and electronics. Let me know if this info helps- have more if needed. Thanks- Ed.
Mar 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning feature
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Clean cycle will not work.
F5 - E0 F5 - E1 and E2 -------- this all codes relates to ----- Check door/latch switch ------------ clean it and check if stiil the same problem ---- Replace switch if defective
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning code error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*^Y
Nov 22, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool GBS307PR Electric Single Oven Logo
1,330 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
