Question about Bosch 11222EVS 1 1/8" Sds Plus Rotary Hammer
(bosch 11222evs 1 1/8" sds plus rotary hammer) so i have replaced the gear assembly due to wear but after regressing the unit it is not hitting as well as it should now all it dose is vibrate. any idea?
  • mccellmour12 May 28, 2010
    grease between the tip of the plunger and the striker pin is creating a vacuum you need leave this part degreased.
3 Suggested Answers
  • 885 Answers
SOURCE: Looking to download a user manual for Bosch Rotary
You can get an owner's manual and parts diagram at: http://www.boschtools.com/Service/ProductServices/Pages/ManualsandDiagramsResults.aspx?type=both&modelNum=11241evs
Posted on Jul 06, 2011
H2_Brad
  • 425 Answers
SOURCE: how to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222evs
Here is a link to the parts diagram. It shows what position the knob needs to be in the remove it. You also have to push the button in further then normal. I just use a small screwdriver. Once you rotate it further past the last position you will be able to lightly pull up on it while slowly rotating and it will release. It has tabs molded into the plastic knob so it can only come out when they align with the housing it fits into.
Bosch 11222 diagram
Posted on Aug 22, 2012
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
How much grease goes in a bosch 11335k?
I believe this tool takes 225 ml of grease, but I would strongly recommend installing a service kit #1-617-000-702
The service Kit comes with grease and all the normal wear parts (highlighted below in black circles) Service Pack 1617000702 for Bosch Power Tool eReplacement Parts
Jun 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Hammer runs and works but pulsates and sparks alot
dasdgaiusgdausydgaysugdasyugd syugdauysgdauysgduyasgd yusagdsayugdausdsaydg sayugdayusgd ayu lkgkljgkglgkgkgkgkgkgkgjgmgjgmgjghfjdgfhgdhdfsbsfgshdgfcjfgdfjhfrgdhdgdhdgv hdgdjhdgdjhdgd jdgdjhd gjdgdjd g djd gd hd gdjd gd hjd gd hjd ghd jhd hgd d awdahwgdyhugdasbgduaysfd yaugduyadyasgidgsdt fsdgauysfdtasfdasbgdyafsiudtfasigy faiustfdaf tsafyuafuysdfayusfy drfasyfdyfasiuydfasyufadiu fysdfasyfdyafs ysafiuyafsuydfasiyudfuyafsiudy fasiuyfdyu afiyufsyudf aisuyfdayus fdiasuyfydfasiyudfayusfd iyuasfdyaufsyudfasiuyda56dr iayfduyfsay ufdayf dasdgpiushdaiudispudaisduapisdysaudy ayiouydasuydioautsdyoiusodyausdy osayuidysuoia ydayduiysuidayuiody osiuadyasudy uisdtauitsdausoidyhautdewuripwoery eiureiruw iuiuiuiuratiuiuiureai iuartu aeriutr ueaituaeriotuaporiutpoei utpreiutpieurtpaoierutaprtuapoitu uterituarepitu aerituaeir tuerutaiot uaiutaiorut aiertueirutpoeiturapioetuapoituerptu7rae8typer tiyte iuyrtya iye tiyaiyaerptyiraept iryatiyr iyaepoirtyapoirtyrapoiti yuioptruaiptypiureity areoiut rpaiutaeytpairtpeyrt part yartyp riyrt arey tytrapeiryt airytpoaiytriot aytpoiriyapo iypoiy poiy oiyypoiuy7tygtyrfgh tfhiujouyfrdftgbhui j iugtrdfyugbhihuhtuif uyhgiuy;ioj;lkjmlk;hujhi hiuohuguyuygyuufyt fuytfufyhguitfgiutyfuyighyuf yuuihufr ikifofgdifgdfgouiydfgoiugfidugpdfigudfpgi
Jan 25, 2011 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
Need \rnBosch Rotary Hammer Manual 11255VSR
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000001/r01003v-1.pdf
here you go!
Jan 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
Connnect drill to keyless chuck bosch 36vfl1
Push or pull the business end toward the body while gently pressing and rotating the bit into it. The chuck will snap back up to retain the bit when you have it lined up right.
Sep 19, 2009 | Bosch 36V 1" Sds - Plus Rotary Hammer
Need sds to hex shank adapter. Where to buy?
If you have SDS-Max, ereplacementparts.com has one made by Bosch that'll go from SDS-Max to 3/4" Hex:
http://www.ereplacementparts.com/sds-max34-hex-rotary-hammer-adapter-p-165057.html
I'm having a hard time finding one that'll do SDS-Plus, though.
Aug 19, 2009 | Bosch Drills
Wanted a sds chuck for my spline chuck
The adaptor you need to convert your slpine to SDS-plus is Bosch part# HA1020. Hope this helps. Dave
Dec 23, 2008 | Bosch 11248EVS Factory Reconditioned 1 -...
Bosch 11222EVS 1 1/8" Sds Plus Rotary Hammer Logo
60 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
