Question about AT&T Palm Centro Cell Phone - White
Palm centro won't charge. New battery in it - AT&T Palm Centro Cell Phone - White
    Genius:
  • 1,417 Answers
HELLO,
this means that your phone have develop charging port problem which means that the port will need to be replace with another better
please note you will have to test your phone charger with another phone of your phone to be very sure that your phone charger is in good condition
if your charger work with it then you need to follow the instruction given above but if it fail then you should test your phone with someone that is using the same phone with you around please the reason for all these is to avoid wast of money
thank you and thanks for using fixya.
Posted on Apr 30, 2010
2 Suggested Answers
  • 9 Answers
SOURCE: replace the keypad on a palm centro
first off you need a t6 screwdriver. this is a special screwdriver with a star shaped bit specifically used for the screws in your centro. if you don't have one, you can buy one off ebay cheap or maybe even borrow one if you go into your local cell phone shop. they probably could even help you replace it if they're nice, even if you didn't buy the keypad from them.
start by taking out your stylus, your battery, and the little rubber plug thing on the opposite corner from your stylus. it just kinda pops out if you get under it with something pointy like your nail. set these things aside somewhere safe. there are six screws to take out, one under where the stylus was, one under where the rubber bit was (there are three holes here, the middle one is the screw hole), and four more that are super easy to see with the battery cover off. take out all six screws and put them somewhere safe too. then gently pry the back housing up from the bottom and pull it downward with a little wiggle and it will come right off. there is a smaller separate piece that surrounds the hotsync cable port and charger port and this comes out too. set these aside.
the next piece we will take out is the motherboard. you will need to disconnect the screen and the keyboard. they are actually under the motherboard but connect to the top side. lay your phone facing down on the surface in front of you and there will be two pieces of black tape toward the bottom of the exposed motherboard, one on either side. gently pry them up, folding them back toward the edges of the phone but do not remove them completely. this makes it easier to replace them later. under the tape are connectors for the ribbon cables that connect the screen and the keypad. there is a small grey bar that locks the ribbon cable in place. gently pry them up, flipping them toward the center of the phone. then gently pull the end pieces of the cables out of the connectors. they will kind of just point up toward you, not flop back over the edge of the phone.
lift up the motherboard by the bottom, like where the hotsync cable goes. pull the motherboard down toward the bottom of the phone while gently (or it will break off) lifting up the part of the housing that covers the speaker and the camera. set the motherboard aside.
now there is a kind of sticker that looks like gray mesh covering the back of the screen and the keypad. pull this up gently from the bottom wherever you can get an edge started to pull it up. you can stop pulling when you get to the part where it's just covering the back of the screen because you won't need to get under there. the flat ribbon cable that goes to the screen might stick to the mesh, and that's ok, just push the whole thing up out of the way.
now you can lift up your phone and gently push the keyboard back through from the front. it will kind of pop out. it helps if you hold the phone facing down still and use your thumbs to kind of push the sides of the phone out a little so the keypad can just pop back. at this point you should have the part that is the keyboard with the cable sticking out of it, and if this is the part you need to replace, ignore the next paragraph. if it's the actual arrow and power keys, read on.
the green and red buttons (or power and talk) and the 5-way navigation button are all connected together and you can replace this whole piece by just pushing it out from the front, and setting the new one in it's place. it's easy to get mixed up, so just in case, the green button is on the left front and the red button is on the right front.
now there's just putting the phone back together. pop the keypad back in (check the front to make sure it looks right and it's popped in all the way). re-stick the mesh back down over top of it. make sure you have both cables showing and they didn't get stuck under there. take the motherboard and slide it back under the speaker cover (lift it up and wiggle), and make sure the cables don't get caught under it. it takes a fair bit of wiggling to get it sitting in there flat. reattach the cables by sliding the ends into the little slot. if you look carefully, there are little guide lines on the keypad cable that come just to the edge of the connector when it's all the way in. flip the little gray bars down to lock the connectors in place and restick the tape. put the little plastic piece from the bottom back on (it only fits one way) and then put the back housing on and push on it until it kind of clicks into place. replace all the screws, the stylus, the battery and the cover. you're done!
Posted on Jul 03, 2009
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Palm Centro will not charge. Red lite comes on
Jim,this shows that the charger and the charging circuit are fine and kicking. Only the battery is debatable. If an old battery then it has gone. even not so old battery could be the culprit. so, replace it.
Sep 08, 2009 | Palm Cell Phones
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
Aug 30, 2009 | Palm Treo 500 Centro
Power
your battery is all the way dead and needs charging, or your battery is not holding any charge and you need a new battery, or, worst case scenario, the phone battery contacts are not working and your phone is now incapable of using a battery.
Jun 23, 2009 | Palm Treo 500 Centro
My palm centro started going dead with a low battery signal literally overnight. I replaced the battery with a new one, and it still won't stay charged longer than 6 hours. Also the phone is now running...
I've had a Centro for 3 months and its such a let-down. Not only does the other caller find that my voice comes and goes randomly during calls but, like you, the battery started playing-up.
You'll find that a hard reset will bring the battery life back up. Hard reset clears EVERYTHING, so backup. To hard reset, remove and replace the battery while holding down the red, drop-call button until you are prompted to hard reset.
You'll find the battery life is bertter again, at least for a couple weeks...
May 15, 2009 | Palm Treo 500 Centro
Palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts  back.
Apr 25, 2009 | Palm Treo 500 Centro
Its locked up
Is your Palm Centro device locked up and frozen. You might want to try a hard reset. Here’s how.
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the second Palm logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Mar 31, 2009 | Palm Treo 500 Centro
I drop my phone centro palm into water! I charge the phone and the red light turns on but my phone wont turn on at all. What can i do
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Hard reset for palm centro
When performing a hard reset on the Palm Centro, you hold down the power button as you insert the battery, and then release the power button when you see the second Palm logo.
http://www.palm.com/us/support/downloads/centroupdate/pop_centrohardreset.html
Jun 29, 2008 | Palm Treo 500 Centro
AT&T Palm Centro Cell Phone - White Logo
479 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
