Question about LG 42LC2D 42 in. LCD HDTV
New sky+ remote volume wont work,put code in for lg 42lc2db all other buttons ok maureen
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 86 Answers
SOURCE: Sky code - LG 47" TV Model Code47LG5020ZB
If there is no code, then there is no code.
The only other option would be to buy a 3rd party remote that is compatible with both devices. Unfortunately there is no way to know if it will actually work until you try it.
Posted on Jun 03, 2009
SOURCE: SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Posted on Sep 02, 2009
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Nov 23, 2010 | LG Televison & Video
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
My lg television model 42lc2db dont know the code tried sky they dont know it, can you help.
Please Follow the steps below
TV
RED + SELECT ( hold these down until it flashes twice)
TV
0056
Try the volume if this works then press the SELECT button. If this does not work the volume then press TV again and then try the volume again. Repeat this step until the volume works then remember to press the SELECT button to save the code.
If for any reason this does not work remove the battery cover from the remote. You should see on there ''REV 4,6,8 you may have an older remote in which case you will need to get a different REV remote.
Hope this sorts you out. If so please leave a thumbs up for me Please.
Cheers
Little Dish Fitter
Sep 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Aug 29, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
My sky remote just newly stopped working, It still works on the tv but when i press tvguide it puts the tv to ch 1 and thats it. Why wont the tvguide work
first of all I would like you to press the blue sky button on the top of your remote. Now press you tv guide button. If this has sorted it Great if not read on!!
what I am going to talk you through now is resetting your remote:
TV
999
now press the blue sky button at the top of your remote now try the tv guide button. this should work no problem now.
now to the small matter of tuning your remote back in to work your volume etc
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jun 05, 2009 | LG 37LG30 37 in. LCD HDTV
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Sky remote code
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Apr 26, 2009 | LG 37LG30 37 in. LCD HDTV
Remote control setup
TV
RED + SELECT
TV
0056
try your volume button if this works press the SELECT button to save the code. if not press TV and then try the volume again. repeat this step until the volume works. then remember to press the select button to save the code
cheers
Little Dish Fitter
Jan 07, 2009 | LG 42LC2D 42 in. LCD HDTV
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
64 people viewed this question
Computer Repairing
Computer Repairing
