Question about Sony Cyber-shot DSC-W55 Digital Camera
DSC W55 Hi to all, When I trun the camera on, the zoom starts to work, I then have "access" writeen on the black screen. Zoom goes in an out and then I'm told to turn the phone on and off again. How can it be resolved? Thanks, Guy.
  • 790 Answers
On another website I found the solution, given by Sandra Cooke.
"The lens is jammed and won’t open all the way. You have to bang on the camera and/or tug on the lens to release it from whatever is causing it to jam when it opens."
Posted on Mar 25, 2008
  • Sony Master
  • 19,396 Answers
Take battery out await two mintes and put battery back in, this should reset the camera.
regards
  • 1 more comment
  • Ginko
    Ginko Mar 25, 2008
    Ensure also that you are using alkaline batteries and that they are not drained. In case try a new set of alkaline batteries(eg.duracell).
  • Ginko
    Ginko Mar 25, 2008
    Yes, in some case jammed lens shutter can give same error, when is like this you can fix the problem playing gently with the lens. Here is a thread from fixya giving solutions for this problem, hava a look.
    regards
  • Ginko
    Ginko Mar 25, 2008
    Be very careful if you decide to bang the camera with your palm or to play with the shutter, all this methods involve a certain risk of damage for your camera.
    If you cannot fix the camera with all the above, I suggest contacting the nearest service shop.
SOURCE:
My DSC-W55 can not zoom when i recording a video, how can i fix it?
You can't. The DSC-W55 does not allow zooming while recording a video. See the second bulleted item under "Using the zoom" on page 15 of the manual.
Sorry if that wasn't the answer you wanted to see, but that's the way the camera is.
Aug 21, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc w 55 - when the camera is turned on - the zoom tries to adjust twice while the disply says access - then it beeps and says turn the power off and on again - it doesn't work
Hi!
The focus is stuck. Contact your local Sony service center, but if they ask too much, you can contact me at [email protected] and I will give you a good price.
I work in Sony service center.
Tom
Jul 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera is turned on , the zoom tries to adjust twice while the displays says" access" then it Says" Turn the power offand on again" Following the instruction does not solve the problem, we can see...
The error "Turn off the power and on again" shows when the zoom motor start malfunction, If you want to repair by yourself and have experience then change the optical zoom motor it will reduce your cost. Otherwise you can change complete lens block assembly, both part and description is given below for your help and convenience:
Part No. Description
1-788-363-11 OPTICS UNIT (ED13A) (complete lens block assy)
2-673-648-01 ZOOM MOTOR UNIT
You can contact any expert or Sony Service Center to change the above said part and your camera work fine again.
Thanks for using fixya.
Jul 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Hi i turn the camera on and have a blurry screen
Zoom motor in lens assembly is jammed and you need to replace complete lens assembly. DSC-T1 is an old camera so oes not worth to repair.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens will not retract after being
the problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Jun 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom button
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera.
You can replace upper part of camera with following part number..
A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part.
Part available in Parts Store for $24
Feb 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Dec 05, 2017 | Sony Cyber-shot DSC-W170 Digital Camera
Camera cant take pic.
HI,
    The optical lens bolck assymbly need replacement,Because the zoom motor get malfunctioning.For this you have to contact any SONYSERVICE CENTRE nearby to you.
 Thanks and dont forget to rate.
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cybershot sont 7.2 mega pixels optical zoom 3X- camera will not stay on
i need to by chargar and connecter for camputar for my DSC-W55 wher and how much is cost ?
Jun 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
