Question about Hoover F7431-900 SteamVac Vacuum
Clean water leaks out of the side of the cleaner when snapped into its place. Maybe not getting a good seal or somthing?
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
You have a bad solenoid. It is supposed to stay closed unless the trigger is pulled but when they go bad they are open all the time. Take it to a vac shop
Posted on May 01, 2010
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Dirty water is not going into the tank, it's leaking out the bott
Check the little door at the back of the unit where the hose attachment plugs in. It has to be shut really tightly and it takes a quick fist smack on it to get mine to "click" and be shut. If that isn't sealed it could leak both clean and dirty water to the floor.
Also, take the dump tank off, check the filter (near the top where the dump tank connects on the machine side) is clear. Also make sure the rubber seal around the filter isn't loose or cracked. Then put the dump tank back on making sure the bottom is seated well first and then CLICK the top into place when you push it to the upright/in place position.
If you are using the hose attachment, make sure it is clicked into place tightly. I have to put one hand on the front of the machine to push toward the back while pushing the other hand on the hose to get it to click tightly in place. If it's not really snapped in there, it will leak.
Apr 19, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
NOT PICKING UP WATER
check to make sure the black valve is seated correctly (tabs should be snapped into place) and that your red lint filter is clean and correctly positioned (IT GOES IN UPSIDE DOWN IN THE PORTABLE WATER TANK, NOT INTO THE BLACK HOUSING OF THE UNIT) so that you have good suction. If you hear air leaking that's an indicator one of the above is not correct.
Jan 30, 2008 | Bissell 8910 ProHeat Clear View Upright...
EEureka Atlantis 2595A Upright Wet/Dry
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much. The only thing the booksays is to put the tank in until it snaps into place. (Like we didn'ttry that.) Apparently it's a bad design. The seal on mine looks fine.
If I was doing the floor I'd just keep going but I'm trying to do my couches and I don't need a huge puddle on the floor.
Nov 04, 2007 | Eureka Atlantis 2595A Upright Wet/Dry...
Leaking
My machine leaked badly BUT it was my own fault. There is a one-time only setup procedure where you squeeze the trigger and push the Clean-Surge button to lock a rod into place. Push the Clean-Surge button VERY HARD. There will be a loud SNAP which sounds like you broke something, but you didn't. I didn't push hard enough initially, all I got was a click which I thought was enough. My machine leaked so I called the help line. They told me to push the button harder, and sure enough, they were right. Until you get that snap, the Clean-Surge (which releases a little extra water-cleaner solution) is on all the time, hence the leaking
Sep 22, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
85 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
