Question about Teac AG-D9100 Receiver
I would like to run my TV sound out of my TEAC AG-D9100. Can I connect my TV sound output to the VCR/VIDEO4 input without a video input and then switch to VCR VIDEO4 to get the output sound? I have the video from the TV connected via my DVD player.
    Brigadier General:
  • 8,546 Answers
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
Posted on May 01, 2010
Testimonial: "Thanks for the tip. Works great."
Install a equalizer to Teac Ag D9100 Receiver
From what I can tell (from photos), you'd hook an equalizer in the Tape 1 or Tape 2 path, where the EQ takes its input from the receiver's Tape 1/2 output and the EQ feeds its output to the receiver's Tape 1/2 input. When you want to switch the EQ into the signal path, you just push the tape monitor button for whichever tape path you hooked up.
Jul 24, 2015 | Teac Audio Players & Recorders
I have a Teac Ag D9100 Receiver how do you install a equalizer
Best way to hook up equalizer is see if receiver has preamp outputs that can be connected to amp inputs. If so hook up equalizer to them and you are in business. Or you can hook up equalizer to the output of the device you want equalized and then hook up the EQ output to any receiver input.
How do I get a teac ag-55manual
There is not much to it. All you will get is a 2 speaker stereo audio. You need to be able to get the stereo audio output from the TV and with 2 RCA cables connect the red and white connections from TV to the TV/ VCR in connectors of the Teac Receiver. But I doubt you will get this output from modern TVs. They usually provide digital or optical output connections. Make sure you have selected TV mode at the front piano key on the receiver.
Sep 02, 2014 | Audio Players & Recorders
Teac d-9100
Check your speaker and speaker connections. Do you have normal display? If so, after checking your speaker and speaker connections and they are ok, you might have a problem with one of your output elements (Mosfet).
Mar 16, 2014 | Teac AG-D9100 Receiver
I have a Teac Receiver AG-D9100, sound cuts off, but if I touch the master volume knob it comes on for a short time. What to do? jmf
This can be related to a fault in the potentiometer as it cut off the tracking of the voltage and gets back to feed the digital circuit. You need to check, sometimes a switch cleaning oil can help.
Try to wriggle the pot control many times as it can help, if not replace.
Oct 07, 2011 | Teac AG-D9100 Receiver
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Jun 01, 2010 | Teac AG-D9100 Receiver
TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
May 08, 2009 | Teac AG-D9100 Receiver
Lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
Jul 11, 2008 | Teac AG-D9100 Receiver
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Teac AG-D9100 Receiver Logo
267 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
