Question about JVC AV-28GT1B 28" TV
Jvc av-28gt1sjf Hi ,my jvc is 4 years old and now the picture has moved to the left tried the zoom button and then the tv went into stand by,it was flicking on and off.then after a while it would come back on but the picyure was still wrong Hope you can help martin
Hey there.
I'm sorry I don't have a solution but I'm experiencing the same problem. Have you been able to resolve this.
Thanks,
MC :)
Posted on Jun 12, 2009
SOURCE:
How to connect xbox to jvc av-28gt1sjf
I assume that since you do not have remote you cannot choose another AV channel on your TV. If so you can use the RF input using a RF converter to AUDIO /VIDEO or if not the sky input must be shared through a VCR/DVD or multimedia/DTS amplifier
Nov 30, 2011 | JVC AV-28GT1B 28" TV
Jvc 57 inch tv. kid did something to change picture size. now too large and bottom is cut off. aspect button on remote when pressed shows a red circle with a line through it.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Apr 13, 2010 | JVC AV-28-BD-5-Bl 28" TV
Jvc av-28gt1sjf
there is a card with the TV Turner that is causing this and needs to be changed its has a microprocessor that control functions of the set .
get it changed and your set will just fine .
have fun
Dec 28, 2009 | JVC AV-28GT1B 28" TV
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
AV-28GT1SJF
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Jun 04, 2007 | JVC AV-28GT1B 28" TV
Jvc television
If you have zoom button on the remote and it doen't work the remote may be defective. If the zoom is in the menu you can go in there an turn it off.
Apr 22, 2007 | JVC AV-32730 TV
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Feb 24, 2007 | JVC AV-28-BD-5-Bl 28" TV
Jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Jun 07, 2006 | JVC AV-28GT1B 28" TV
JVC AV-28GT1B 28" TV Logo
181 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
