Many Garmin GPS units that only get powered by the car charger / cradle suffer from this problem eventually. The fix is pretty simple. You didn't include your model GPS, but I think this may help just the same:
Connect the GPS to a computer's USB port, or AC adapter that has a USB port and leave on for 8 hours (or over night). Disconnect and and turn on again. If you have a Nuvi that has a spring return sliding power switch - slide and hold it in the on position for 15 seconds before letting go. It should power up just fine. You do not need to hold the power switch like this again to turn it on.
If the GPS starts acting like this again, simply repeat the process as often as needed. Eventually, the internal battery will no longer be able to accept a charge and will require replacement.
Have you checked the fuses in the power cable? There is a reset button under the front bezel. Try pressing that to see if your unit comes back to life too.
I can help you reset and fix your Garmin Nuvi 265W.
Getting
stuck on the flashing Garmin logo, or a message about not finding any
maps, are indications that the firmware / system software inside your
GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
I have found the only thing that works thus far is to click on the red phone in progress icon then go to "call options" then click transfer audio to phone, then transfer audio to nuvi. Sometimes I have to do this twice. but it works.
