Question about Refrigerators
Fisher and Paykel fridge. It's stopped making ice and the water dispenser became erratic and has finally stopped. The display simply shows f31.
  • matthewkarpi Apr 30, 2010
    Not much help at all really. The solution could only be completed by an electrician which is just the same cost on top of paying for this service.
  • Brendan V
    Brendan V Nov 03, 2014
    Also, turn off fridge before doing repairs or the error code will remain despite the healthy condition. I had to fix 3 wires before the code was cleared.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F31 on you Fisher & Paykel means no display signal, short/broken wire. Whenever a fault has occurred relating to the display board the fault code is displayed. To start with remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment with the correct model no# for further assistance.
Thanks
Rylee
Posted on Apr 30, 2010
Fisher and Paykel RF201ADUX Refrigerator - error code F30 F31
I found loose wires under the top right hinge, where you will find a small connector block. Put the loose wires back in and hey preso the lights were back on, the water and ice defenses worked and the fault code was cleared
Mar 19, 2012 | Fisher and Paykel Refrigerators
My 3mth old e522brxu fisher and paykel ice maker has stopped working water is working fine you can manually force a dump and hear the cycle start to turn the tray but no water fills the tray can not hear a...
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
May 26, 2011 | Fisher and Paykel E522BRXU Fisher & Paykel...
Model E522B - Ice Maker not working - forced cycle does not flip tray. Water dispenser is working ok. Freeze r temperature set low.
freeze tempt even tho set low / how low is it / must be 0 to 5 deg too work well . it stops at 15 deg .. . make sure both fans are working and the cond coil is clean . .. very important . .. water disp does not work with ice maker . you have a dual valve in the back with two coils . the ice side may have gone bad . if so replace the valve . both sides / only way it comes . hope this helps **** ..
Jan 06, 2010 | Fisher and Paykel E522BRXU Fisher & Paykel...
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
776 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
