Question about Sony RM-AV3000 LCD Touchscreen Remote Control
Sony RM-av3000 Programmingproblem
I've been using my 3000 for 5 years now without a problem. Yesterday i wanted to learn it a new remote and teh following problem occured. When i teach a button a function it will work with that function, but when i now teach another button a function both buttons will have the same function. At the end i found out that all buttons that i had programmed had the same function as the last one that i had programmed. I've called Sony and they don't have a solution. Does any of you?
    Top Expert:
  • Sony Master
  • 76,140 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on May 25, 2017
3 Suggested Answers
SOURCE:
  • 23 Answers
SOURCE: it is broken. I have sony integrated remote commander RM-AV3000 .Need codes
what is a mySTR-DE698? but more generic, like brand and what it does. TV or DVD etc...
Posted on Oct 15, 2008
SOURCE: Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Posted on Mar 16, 2009
Sony rm-av3000 commander, no code for newer sony av receiver
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Try this link too
Apr 19, 2014 | Sony RM-AV3000 Integrated Remote Commander
What universal remote control will work with a Norcent flat screen tv
Everyone says the Harmony (by Logitech) will run anything. If you don't want to spend that much, consider a learning remote. You use the existing remote (assuming it works) to program the new one. Something like: Sony RM VLZ620
Sep 10, 2013 | Televison & Video
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Sony RM-VZ320 Remote Control
I am trying to program my AV3000 to work with my Dish Network Sat Receiver. Any help? Thanks so much.
Hi my nameis Mike Houston of DISH Network and I caught your post and see you want to programthe Sony RM AV3000 to the DISH Network receiver. To have full access to the menusand functions of the receiver it is best to use the DISH remote for the systemyou have, I will send a link for the RM-AV3000 to help with the setup for theremote. If you have any questions please e-mail me at [email protected]
Dec 26, 2010 | Sony RM-AV3000 LCD Touchscreen Remote...
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
It is broken. I have sony integrated remote commander RM-AV3000 .Need codes
Oct 14, 2008 | Sony RM-AAP001 Remote Control
Sansui > DTV2760 27" TV
I have a sony rm-av3000 universal remote and am trying to get the code for the Sansui DTV2760 TV?
Sep 05, 2007 | Sansui DTV2760 27" TV
Sony RM-AV3000 universal Remote
You can find out if the remote is broken by taking a camera with an LCD viewfinder (such as a camera phone) in a dark room, point the remote at the camera and in the viewfinder you will see a light coming from the remote if it is working. If you see a light, chances are the remote is good. You may need to reprogram the remote.
Mar 04, 2007 | Sony RM-AV3000 LCD Touchscreen Remote...
Sony RM-AV3000 LCD Touchscreen Remote Control Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
