Question about Sony DCR-HC21E Mini DV Digital Camcorder
"Lens cover not open" message
Hello, I have a Sony DCR-HC21E and it keeps displaying a message on the LCD flip screen saying "Lens Cover Not Open" when infact it is open. Any advice please? Thanking you in advance, Tim.
[email protected]
There is a switch sensor which will detect if the switch is open. Try switching rapidly a couple of times, as dust must be lodged.
Posted on Oct 12, 2008
6ya staff
SOURCE:
My DCR-HC30 Mini DV Camcorder keeps giving me the "cover not open" indication when the cover is actually open. What can I do to resolve problem?
There is small switch located at front circuit board that is not working properly and causing "cover not open" message.
Take off LCD cabinet section then remove front cabinet section, remove screws on circuit board and turn it to see that switch.
There can be lose connection on switch terminals or switch is not being pressed properly with lens cover lever. Please check it carefully.
Thanks.
Oct 22, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD Screen not working
the problem of your camera is the flexwire cable of the lcd monitor that why you don't see nothing in the panel,Also the message 'cover is not open' appears,while the cover is already opened the switch on cover have poor contact..it is not covered by sony service...it have to replace or repair that switch and flexwire cable....
Aug 20, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
Aug 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC21E Mini DV Digital Camcorder Logo
181 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
