Question about Amana Refrigerators
Model SSD25TE Ice maker does not work. Replaced "Ice Maker ***." PS2121513. Water inlet switch test OK. Whats next.
  • 10 more comments
  • alphavisions Apr 30, 2010
    Amana side by side refridgerator model # SSD25TE.
    Replaced "ice maker ***. # PS2121513".
    What is next?
    Is there some sort of thermocoupler that mounts to the back of the :ice maker assembly" with the wiring?
    In response to your reply:
    Water flow is good.
    Water inlet valve test OK.
    Auger motor is not problem. There is no ice being made to auger.
    The voltage and bad motor you are referring to, is that the auger or the "ice maker assembly" that I have already replaced?
    Where is the control board (module time delay)?
    You still there?
    Does the control board control the ie maker or the auger? Again I do NOT have an auger problem.
    How come I can not see what I have typed? I only see your part.
    You are not answering my question in a manor where I can determine if you are telling me that this test is for the ice maker assemble or if you are stuck on the auger. If you are stuck on the auger then I do not want to waste my time checking it. If this test is for the ice maker assembly then thank you I will do the test and get back to you later.
    But please clarify so that I know I am not wasting time ont the auger.
    Thanks.
    You still there?
    Please respond so we can be done for now.
    If I ask another expert can he see our progress or do we have to start all over?
    OK thanks, I will do the voltage test tomorrow. Can I just log back in and pick up where we left off? If I need a control board can you give me the part number or is it just 0012?
  • alphavisions May 01, 2010
    If the auger runs wouldn't that answer your questons about voltage?
  • alphavisions May 02, 2010
    What voltage is this wire going to show on a system that is working perfectly???
    This test can not possibly be conclusive. If the system is working perfectly then the wire is either going to show voltage or not show voltage, there is no other choice. Yet your test says if it has voltage the motor is gone. If it does not have voltage the control board is gone. This test leaves NO POSSIBILITIES for a perfectly working system. How can this test say when there is no problem?
  • alphavisions May 03, 2010
    nope, not woking
  • 3,083 Answers
Does it get water, and does it freeze, but not get ejected? Just a wild guess, but it sounds like the ejector motor/timer isn't getting power. There's also the slim chance that the replacement unit is faulty- rare, but it happens. Either that or some locking lever isn't released. If all else fails, read the directions thoroughly, there might be some little something that needs to be done. Hope this helps.
Posted on May 04, 2010
  • 713 Answers
Hi,please follow the stepwise solution below to help you fix your icemaker;
STEP 1 Inspect the water supply line for any signs of cracking or crimps in the line. A pinched water supply line can keep the water from getting to the ice maker, resulting in no ice or smaller than desired ice cubes. Check to verify that the water supply valve is open enough to provide an adequate supply of water to the ice maker.
STEP 2 Flush out the water supply lines if you are noticing a bad taste in the ice cubes. This can be done by disconnecting the lines and running hot water through them. Turn on the hot water at the sink and place one end of the water supply line near the tap, holding it in place to allow hot water to run through it. Place the other end of the supply line in the sink to allow the water to drain through.
STEP 3 Reattach the water supply lines to the water supply and refrigerator. Repeat step 2 for the water inlet hose which runs from the inlet valve to the ice maker. If the water supply lines are old or discolored, consider replacing them with new water supply lines.
STEP 4 Check the temperature in your freezer to verify that it is getting cold enough. The freezer's temperature should be at 5 degrees and can be set with a control dial, normally located in the refrigerator compartment of your appliance. To test the freezer's temperature, place a cup of cooking oil in the freezer with a cooking thermometer sitting in the cooking oil. Allow the oil to sit in the freezer for 2 hours and then check the temperature.
STEP 5 Check the ice maker's shutoff arm to verify that it is operating properly. To work normally, the shutoff arm should be in the lowered position. Inspect the arm for anything blocking it or preventing the arm from moving freely. Lift the arm up to see if the unit shuts off in the up position.
STEP 6 Unplug the refrigerator from the electrical outlet and remove the faceplate of the ice maker's shutoff switch with a screwdriver, located on the ice maker. Remove the entire ice maker unit from the freezer by undoing the screws that are holding it in place. Unplug the ice maker from the freezer and take it out of the freezer to work on.
STEP 7 Remove the mounting plate on the top of the ice maker by unscrewing the screws and lifting it off the unit. Locate the shutoff switch, which has three electrical wires attached to it. The shutoff switch is located directly under the shutoff arm of the ice maker. Pull the electrical wires off of the shutoff switch with needle-nose pliers and label them so you know how to put them back correctly.
STEP 8 Inspect the electrical terminals for any rust or corrosion. Use an electrical testing meter to verify that the shutoff switch is working properly. You should get a reading of 0 or infinity on the meter. If the shutoff switch is not giving a reading, replace it with a new switch and reattach the electrical wires to the switch.
STEP 9 Place the mounting plate back over the ice maker and attach it with screws, then reattach the entire ice maker unit to the freezer. Plug the ice maker wiring back into the freezer and put the face plate back over the front of the ice maker
STEP 10 Plug the refrigerator back into the electrical outlet and allow the refrigerator to run for a couple hours. Inspect the ice maker to verify that it is working properly.
Thanks and take care
Posted on May 02, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 30, 2010
  • 8 more comments
  • Rylee Smith
    Rylee Smith Apr 30, 2010
    The motor I was referring to is the Auger and please check part#12 in this diagram which is the control board:
    Thanks
    Rylee
  • Rylee Smith
    Still here, please check the previous comment.
  • Rylee Smith
    Yes right as I said if there is no 120VAC then the control board has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Dont know but I can see your part and my part as well
  • Rylee Smith
    I believe your question was for the ICE Maker not Auger. Auger motor with the control board is responsible in functioning of the Ice Maker so that was the reason I advised you to test it to determine what is the fault the control board or the motor as you have already replaced the Ice Maker assembly. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Still here, please see previous comments.
  • Rylee Smith
    Please see my previous two comments, have already responded twice.
  • Rylee Smith
    I believe other expert will be able to see your comments not mine so its your call whatever you want to do. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Please click on this link for control board. You are right you can log back in tomorrow and then post a comment regarding your progress with your Refrigerator. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith May 01, 2010
    This is the test procedure which should be followed: remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Ice maker stopped working. I've replaced the RO
HI. First, you will need to rule out any standard issues that will cause this. Check the internal, and external feed lines for any obstructions. Make sure that the internal lines are not frozen, or kinked. If the lines check out ok, move on to the water filter(if equipped).
In most units, there will be a filter, present. These devices are set to operate on a particular time frame. If their filtering limit is met, the filter will stop filtering water, thus, not allowing the fluid to flow, at all. Make sure that the filter is up to date. If you have verified that the filter is ok, move on to the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to Remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. the multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Now. If the inlet valve is operational, and it has passed the above inspection, this will lead to a faulty inlet switch. This will be located, and mounted on the ice maker module board. First you must make sure of the design. Most ice maker control sectors are the module type and some are the traditional type. the traditional type is refereed to as a component ice maker. These are easier to work on. They have the gear components exposed, just behind the face plate. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. These are not serviceable. You will need to replace the entire module, if this is your type. The inlet switch is not accessible. The ejector motor, and mold heater are the only components that can be tested on a module style ice maker.
To determine which model you have, Remove the outer face plate. If there is a knob, pull it off first, then pry off the face plate with a small screwdriver. If it is a component style ice maker, follow the procedure below to test the inlet switch. if it is a module type, simply replace the entire ice maker. it is not repairable, due to the fact that the inlet switch is not accessible.
component ice maker inlet inspection procedure:(unplug the unit before attempting this inspection)
First you will need to Remove the entire ice maker form the unit.The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, Remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so already. Just along the the edge, nearest the shutoff arm, a pin protrudes through the mounting plate. The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker structure.
the inlet switch is located on the mounting plate, near the cam. the inlet switch is mounted on a thin plastic insulator and can be differentiated from the holding switch which sits on a thick spacer. the inlet switch also uses only two wires, while the holding switch uses three. Remove the switch by removing the two screws that hold it in place. The switch is connected by two wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors.Firmly pull the connectors off of the switch terminals NOTE_ If the connectors are corroded, try to clean them. if the connectors cant be cleaned, simply, replace them.
Now, it is time for the testing section of the procedure.Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Touch one probe to the side terminal and the second probe to each of the other terminals. The reading should be zero on one terminal and infinite on the other. Now, repeat the test while depressing the switch, the readings should now be the reversed. If the switch fails the test, it should be replaced.
* NOTE_ If you have the component type, i would verify motor functions, as well. Test the motor for continuity using a multimeter. Set the multimeter to the ohms setting X10. Touch one probe to the wire from the wire cap. Touch the other probe to each of the two other wires in turn. The reading should be between infinity and zero for each wire.If the motor test results in a zero or infinity reading on either wire, the motor should be replaced.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Will not make ice. Not calling for water to ice
* NOTE_ If you have the component type, i would verify motor functions, as well. Test the motor for continuity using a multimeter. Set the multimeter to the ohms setting X10. Touch one probe to the wire from the wire cap. Touch the other probe to each of the two other wires in turn. The reading should be between infinity and zero for each wire.If the motor test results in a zero or infinity reading on either wire, the motor should be replaced. ...
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Can not get water to ice maker and water the nothing on front panel will work
Jan 14, 2010 | KitchenAid KSCS25FKSS Side by Side...
Seems water is not getting to ice maker
Jan 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
HSS25GFPD icemaker stopped working. Blinking green light.
Jan 07, 2010 | Hotpoint Refrigerators
I have model 106.56582500 w/ice maker.water will
Jan 05, 2010 | Kenmore Refrigerators
The ice maker is no longer making ice. What are the possble problems?
OK, This is indeed a component type. You stated that the unit is not receiving water. Follow my procedure below to address this problem further.
Dec 28, 2009 | Estate Refrigerators
Auto ice maker stopped working. verified water supply to fridge inlet valve solenoid and shutoff arm is in on position. No noise. Thermostat? solenoid?
  • NOTE_ If you have the component type, i would verify motor functions, as well. Test the motor for continuity using a multimeter. Set the multimeter to the ohms setting X10. Touch one probe to the wire from the wire cap. Touch the other probe to each of the two other wires in turn. The reading should be between infinity and zero for each wire.If the motor test results in a zero or infinity reading on either wire, the motor should be replaced.
Dec 24, 2009 | Kenmore Refrigerators
Ice maker stopped working. Not delivering water to ice maker. Cleared all ice in the maker and the signal to show that the ice container is clear appears to be working. This has worked fine for several...
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Now. If the inlet valve is operational, and it has passed the above inspection, this will lead to a faulty inlet switch. This will be located, and mounted on the ice maker module board. First you must make sure of the design. Most ice maker control sectors are the module type and some are the traditional type. The traditional type is refereed to as a component ice maker. These are easier to work on. They have the gear components exposed, just behind the face plate. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. These are not serviceable. You will need to replace the entire module, if this is your type. The inlet switch is not accessible. The ejector motor, and mold heater are the only components that can be tested on a module style ice maker.
To determine which model you have, remove the outer face plate. If there is a knob, pull it off first, then pry off the face plate with a small screwdriver. If it is a component style ice maker, follow the procedure below to test the inlet switch. if it is a module type, simply replace the entire ice maker. it is not repairable, due to the fact that the inlet switch is not accessible.
Component ice maker inlet inspection procedure:(unplug the unit before attempting this inspection)
First you will need to remove the entire ice maker form the unit.The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so already. Just along the the edge, nearest the shutoff arm, a pin protrudes through the mounting plate. The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker structure.
The inlet switch is located on the mounting plate, near the cam. The inlet switch is mounted on a thin plastic insulator and can be differentiated from the holding switch which sits on a thick spacer. The inlet switch also uses only two wires, while the holding switch uses three. Remove the switch by removing the two screws that hold it in place. The switch is connected by two wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors.Firmly pull the connectors off of the switch terminals NOTE_ If the connectors are corroded, try to clean them. if the connectors cant be cleaned, simply, replace them.
Dec 23, 2009 | Kenmore 53562 / 53564 / 53569 Side by Side...
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Refrigerators Logo
131 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
