Question about Panasonic PT-AE900U Multimedia Projector
My projector keeps flashing to blue screen. Is this an indicator that the lamp needs replacing?
SOURCE: Dell 3200mp lamp not working
check out this link with the solution:
http://www.dellcommunity.com/supportforums/board/message?board.id=proj_2200MP&message.id=2136
i'll also copy and paste it below:
Mods, this should DEFINITELY be in the FAQ's. ***This should probably only be done if your warranty is expired, i'm not sure if taking apart your projector will void it or not, so do at your own risk. (Personally I had nothing to lose, the projector wouldn't work and Dell wouldn't help me so I had a $1500 pile of plastic with no good use) OKAY, if your projector is flickering, the picture is jumping up down left and right, then it shuts down and the lamp light comes on it is NOT THE LAMP!!! Don't let anyone tell you otherwise! Well,,, at least try this first. For some reason dust on the main board causes this, sounds ridiculous but it's true. I have a 3200mp and just did this 2 hours ago and the projector is as good as new. For a 3200mp: There are four very small phillips screws on the bottom of the projector... remove those. There is one very small phillips screw on the right hand side of the unit if you are looking at the projector from the front.... remove that. Now flip the unit so it is right side up and remove the top piece of plastic (The bottom doesn't come off at all. BE CAREFUL, THERE IS A RIBBON ATTACHED TO THE TOP PIECE SO LEAN IT AGAINST SOMETHING. Now grab a vacuum and your air compressor (or can of duster) and go to town. There will be huge plumes of dust come from under the lamp so keep your vacuum close. Next take the lamp out and clean off the glass lens (there is probably some dust on it) Put it all back together and it should work like a charm!
Posted on Feb 24, 2008
  • 221 Answers
SOURCE: lamp replacement
if the lamp warning light is lit steadily, the lamp is at fault. if the lamp warning light is flashing, the ballast (lamp power module) is at fault
Posted on Oct 31, 2008
SOURCE: Panasonic PT L501u Replacement Lamp
panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
thats all the unit powers off & when u check the lamp counter , its shows 0
u r done!!!!!!
Posted on Feb 08, 2009
vortash
  • 431 Answers
SOURCE: lamp indicator flashes three times even with new lamp.
Check your manuel for Lamp counter reset facility , lamps sometimes will not retsrat untill this is done ... Regards Vortash
Posted on May 10, 2009
  • 3 Answers
SOURCE: Projector problems
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
Red lamp or heat light is flashing while projector is off. Can't be sure which it is because it is mounted 16' up. I've cleaned projector & filter with canned air from 12' ladder and red light stops...
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Feb 19, 2011 | Panasonic Projector Lamp for PT-LB50...
A section of the screen is a different colour to the rest. A brighter blue colour. Is this an indication that the lamp needs replacing?
hi,
it will not be because its lamp problem. if lamp have any problem it will affect the whole screen. may be its lcd or controlling circuit have some problem.
ok
Dec 20, 2010 | Panasonic ET-LAE700 Projector Lamp for...
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    WHY DOES A BLUE LIGHT CONTINUE TO FLASH ON TOP AFTER THE SCREEN HAS WENT OUT AND WANT COME BACK ON DOES THIS MEAN THE BULB NEEDS TO BE REPLACED
    how many times does it flash? could be lamp, fans or overheating. clean it out with canned air. if the lamp has bulges, black spots, or fogging, replace the lamp.
    Dec 08, 2009 | LG RD-JT91 Multimedia Projector
    Working but lamp warning on screen,lamp led flashing
    Press < and > and Power buttons at the
    same time on the projector to reset the
    lamp hours counter
    May 12, 2009 | Mitsubishi SL1U Multimedia Projector
    My in1 projecter keeps turning itself off
    if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
    Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Panasonic PT-AE900U Multimedia Projector Logo
    650 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
