Question about LG WM2688HWM TROMM SteamWasher
LG Tromm 4.0 Ultra Capacity WM2455HW Fabric Softener dispenser will not drain
  • KMKM May 26, 2013
    My fabric softener won't drain either!
  • KMKM May 26, 2013
    The bleach just runs straight through to the drawers UNDER the washer, where the CLOTHES are!
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric softener dispenser no longer works on my Bosch
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
Posted on May 20, 2009
MNTECH
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have noticed that there is a build up of water
i had this problem. the fabric softener was too thick. i left it out of several loads and eventually the buildup went away. after i have used a thiner softener and have had no problems since.
Jan 11, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My dispenser is jammed Lg Tromm wm2277hb
you will have to raise the top if its top loading and disconnect the hose connected to it,if its the detergent dispenser and if it's the fabric softener one with the bleach dispenser with it there will be two hose connected to it and possibly some clips holding it in not sure all machines are different.
Aug 23, 2009 | Washing Machines
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
May 23, 2009 | LG WM1814CW Front Load Washer
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Fabric Softner section won't fully drain....
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
225 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
