Question about Craftsman Rear Mount Tiller
Tillers rotate put in gear wont move was moving just stopped is their a belt or chain in gear box or transmisson
  • 1,498 Answers
Hi pat,
Yes, there are two chains in the tranny. If the wheels spin freely but don't engage, the smaller chain is broken.
If the wheels don't move, in gear or not, the smaller chain is broken and wrapped around the gears.
It's a bit of a chore to get to....
Mike
Posted on May 15, 2011
Why did my tines stopped working
Hello, Did you notice if the tines moved when you turned the belt pulley to install the new belt? If the tines do not move when you rotate the driven pulley by hand, the worm gear might be stripped. If the tines do move when you rotate the driven pulley by hand, the belt tensioner might not be working properly. It could be as simple as an adjustment.
Aug 28, 2014 | Garden
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Tiller wont move forward
If its not self propelled you must push it tynes only dig they dont pull the machine forward a self propelled means it has wheels on the back of unit that is chain or belt driven
Mar 10, 2014 | Honda FG201
Grinding gear box in DRT900 tiller?
This machine has a fairly simple chain drive to the wheel axle shaft, there is a sprocket on the shaft itself, this may have started to move on the shaft, the only answer here is to strip the gearbox, once the box is away from the engine and sundry parts it is just a matter of removing 30 or so screws to split the box, it is a grase filled box so there is no need to drain.
May 02, 2012 | Husqvarna Garden
My tiller stopped moving during use, after enitting a puff of smoke. The motor still works well; it does not move, however. Is there a belt that could be burned out? Is this something that can be...
You don't say where the smoke came from but check out the worm gear box and see if gear is eaten up. Supposed to be greased regularly but gear can wear out over time or overloaded digging. . Don't know your model but here is manual on one of them. See if it helps. Look fer it!
http://mantis.com/global/assets/owners_manuals/08_tillers/401702.pdf
May 14, 2011 | Mantis 2-Cycle Tiller
It doesn't want to move in gear. forward or reverce. ILs there a shear pin in the gear case? Thank you David
First off how handy are you i can tell you what it is if you can take it apart there is a chain in the gear box that is connected to a pulley. do you see the guard above the tire that is where the belt drives the pulley that is the other possibility the belt. The chain inside looks similar to a chain on a motorcycle . if the chain broke you can get True Vaule to repair the broken link or you can add a removable link. Electric Scooter Sprockets - ElectricScooterParts.com .check this site out if it is a sprocket they might even have chains to use. It takes some time to get apart but it not to expensive of a fix .if you have more questions write me back.
Mar 03, 2011 | Husqvarna PRRT850X 960920015 CA 17" Rear...
TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE? MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | Mtd Products Yard Machines 158CC Tiller
My 1994 nissan maxima has no problems.but all of a sudden i parked it and when i tried to put it in gear,it wont move.it stays in park.and it wont move
Check your linkage under the car on drivers side. Right next to Transmisson the linkage that goes to your shifter should connect to the linkage coming out of the transmisson. If not, you have a broken linkage.
Feb 23, 2011 | 1994 Nissan Maxima
I have a lazy boy tiller with chaine drive, its liked locked up. it will not engage, any help please ! it does have aplace to put oil on the side of the chine drive house. what kind of oil would it take?...
The gear box can be removed, reset and resealed using gasket magic. It is not a quick fix and during this process I also replaced the tine shaft seals as I had lubricant leaking from the gear-box to the tine shaft. When you are tilling you should avoid rocky areas. It iseems sudden tension due to bouncing is what knocks the chain loose.
DO NOT remove the belt pulley from the top of the gear box. It is unecessary. You must remove the entire assembly from the rear of the machine. It is set in place by 6 bolts and come off as a whole unit. Once it is removed then undo the three bolts and spacers that hold the case in place. Remove the case from the frame by sliding it out the open end. You will have to remove all of the bolts around the outside of the case; a cordless drill really comes in handy here. Lay the case on its side, as you remove the bolts you may experience lubricant dripping from the centers of the removed bolt holes, or at the center holes where the case connected to the frame. This is not a problem as you will need to replace the 90 weight lubricant after you have resealed the case anyway. Once you have removed all of the bolts, using a flathead screwdriver and a mallet or hammer. break the seal around the outside of the case. You may have to go around a few times, but eventually it will pull apart revealing the sprockets, bound chain and remaining lubricant. Since it is open this is an ideal time to check for wear on sprockets and remove any large debris from the case. reset the chain so that the tine shaft moves freely and the corresponding sprockets spin as you move the tine shaft. Using a gasket sealant (Gasket Magic**) put a thick bead of sealant in the center of flat outside edge where the two sides of the case come together. Add a little extra around bolt holes. Replace the two covers snugly together and begin finger-tightening the bolts back into the crank case. Once you have completed this task, go back over the bolts and tighten with a hand wrench. Once the case is back together allow 45m to an hour for the sealant to completly harden before introducing lubricant to the system. Then reattach the case to the rear assembly and then put your tiller back together.
This occurrence seams to be an issue with these machines, however the problem is avoidable as it is persistant use in rocky or hard ground areas which causes causes the system to jump and bind. If you happen upon a hard patch of earth or rocky area, go slow, do not force the tiller and remove any large debris when possible before tilling.
Jun 16, 2009 | Garden
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Craftsman Rear Mount Tiller Logo
154 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
