Question about Bissell 6594 PowerForce Bagless Upright Vacuum
The belt isn't spinning with the metal piece at the bottom.
When it turns out the belt and brush don't spin but the metal piece of the motor is spinning and it smells because the rubber is burning when it gets turned on..
    Sergeant:
    Champion:
  • Bissell Expert
  • 357 Answers
Replace the belt. It is stretched out
Posted on May 01, 2010
Bissell Proheat brushes don't turn. Belts fine.
Make sure the brushes are not seized or restricted
Aug 27, 2017 | Bissell 8920 ProHeat 2XTM Upright Vacuum
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
I have the bissell power force bagged upright vacuum and the brush is not turning, I have replaced the belt but the brush will not move but the metal piece that is hooked to the motor that spins the belt...
sounds like your brush roll is seized. Remove the brush roll (see picture) and make both of the end caps spin freely. If not, replace it and you should be set.
*An example of a brush roll*
Make sure that the brush roll spins freely.
Hope that helps.
Chris
Jun 09, 2010 | Bissell 3522 PowerForce Bagged Upright...
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Belt keeps snapping
Check your brush. It is likely that the brush is broken and will not spin. Hold the brush by the end caps and spin the brush and if it will not spin freely that is your issue.
Oct 31, 2008 | Bissell 3576 CleanView II Bagless Upright...
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
298 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
