Question about Siemens SpeedStream Modem (4100) (SS4100)
Connection problems, dsl green light off and on
  • 68 Answers
Please ask you ISP to run the line test on your line. If the test passes then the modem is faulty.
Posted on May 03, 2010
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Not connected to internet via dsl nor green light on DSL
If ur DSL in not green that means problem with the service provider. So, just contact with the service provider
May 25, 2011 | Zyxel Prestige 660R Router (91004397002)
DSL Connection is not working.. The DSL green light on the Speedtouch box is continuously flashing..? help please
If the DSL light on the modem is flashing it most likely indicates a problem with the DSL connection. Check with your ISP.
Jan 19, 2011 | Computers & Internet
My router ask me Not Connected... Your DSL connection is down. tell me whats problem wireless light is red power is green & ethernet is green light & internet &...
You need to check with your DSL provider. What the router is telling you is that it is not getting a connection with your internet provider. Contact you internet provider, they all have Techical support and they will help you solve the connection problem on their end. It may be in the DSL modem or there may be an outage in your area.
Brian
Dec 24, 2010 | Computers & Internet
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
1st time installation: cannot install modem properly
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Jan 14, 2009 | AT&T High Speed DSL Modem
Siemens SpeedStream Modem (4100) (SS4100) Logo
308 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
