Question about Casio FX-260 Calculator
How do I use the standard deviation function?
How do I use the standard deviation function on the calculator?
  • Casio Master
  • 7,993 Answers
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Posted on May 02, 2010
SOURCE: standard deviation
image001.gif Enter the first number, 1.
image001.gif Hit the σ+ (Sigma+) key. ( n=1 will appear in the window)
image001.gif Enter the second number, 1.
image001.gif Hit the σ+ (Sigma+) key. (n=2 will appear in the window)
image001.gif . . . . .
image001.gif Enter the last number, 7.
image001.gif Hit the σ+ (Sigma+) key. (n=7 will appear in the window)
image001.gif Hit 2nd x2 (by hitting the 2nd key you are actually selecting the x-bar written above the key.) This gives you the mean.
image001.gif Hit 2nd sqrt(x). This gives you the sample standard deviation which we will use in class.
image001.gif Make sure you turn your calculator off and on for new data sets.
Posted on Jan 26, 2008
SOURCE: Standard Deviation
When I enter some series of data and check the descriptive statistics, every time I come to the standard deviation the calculator shows me Error 1 message.
Posted on Oct 20, 2008
Is there a PDF with the Statistical procedures for this product? I bought my Casio FX-115 used (second hand). No instructions. I need help using the Statistical functions for my Stats classes:
Correlation Coefficient
Standard Deviation/Variance
Chi-Square
x-x(bar) summations
HELP!
Posted on Nov 19, 2008
  • 718 Answers
SOURCE: finding standard deviation on Ti-30XA calculator
You can get instructions from;
http://www.geocities.com/calculatorhelp/ti30xa.htm
It's straight forward to follow.
Posted on Apr 18, 2009
  • 7993 Answers
SOURCE: HOW DO I CALCULATE STANDARD DEVIATION ON MY TI34II
Here is an exemple taken from your calculator s guide book
f1dd02c.jpg There is no substitute for reading the user guide.
Hope it helps.
Posted on Sep 14, 2009
How to calculate standard deviation
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
Sep 23, 2011 | Texas Instruments TI-84 Plus Silver...
Can not find Calculator Solution Data Input Function Key for corp finance work on bonds valuation.
To enter data in stat mode, use the Change key.
MODE 1:STAT
Choose Standard deviation or any regression model
In standard (0:SD) deviation,
If a data item has a frequency larger than 1 (the elemnt is repeated), the sequence is as follows. 15 repeated 3 times
15 [(x,y)] 3 [DATA]
Feb 06, 2011 | Sharp ELW535 Calculator
How do I put my calculator in statistics mode?
The TI-30XA does not have to be switched to a statistics mode, the operations are available all the time. The choice of operations are somewhat limited; the calculator offers statistics functions for one dimensional data sets only (no linear interpolation of (x,y) value pairs, for example):
  • [2nd] [CSR] - erase statistics data
  • [mib8888_17.gif] - add a number to the sample set
  • [2nd] [mib8888_18.gif] - remove a number from the sample set
  • [2nd] [FRQ] - multiple entry of the same sample value
  • [2nd] [n] - sample set size
  • [2nd] [mib8888_19.gif] - sum of all sample elements
  • [2nd] [mib8888_20.gif] - sum of the squares of all sample elements
  • [2nd] [mib8888_21.gif] - average of the sample set
  • [2nd] [mib8888_22.gif] - standard deviation (sample set is a complete set)
  • [2nd] [mib8888_23.gif] - standard deviation (sample set is a subset of a larger set)
The calculator displays "STAT" if the current sample set is non-empty.
Example: calculate the average and standard deviation of the set { 3, 4, 5, 5, 5, 5, 6 }.
  1. [2nd] [CSR] - erase stat memory
  2. 3 [mib8888_17.gif] 4 [mib8888_17.gif] 5 [2nd] [FRQ] 4 [mib8888_17.gif] 6 [mib8888_17.gif] - enter the data, note the use of [2nd] [FRQ] to enter the four occurrences of "5". Entering 5 [mib8888_17.gif] four times would have done the same.
  3. [2nd] [mib8888_21.gif] - display the average of the set, (4.714...)
  4. [2nd] [mib8888_22.gif] - display the standard deviation of the set (0.8806...)
Jan 25, 2011 | Texas Instruments TI-30XA Calculator
How do i solve standard deviation with this calculator
The stdDev( function in the LIST MATH menu will calculate the standard deviation of a list. You can provide a second list if the data is grouped.
For detailed information refer to the "Lists", "Statistics", and "Infererential Statistics and Distribution" chapters in the guidebook. If you've misplaced your guidebook you can download a copy from
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=2&appId=6125
Sep 11, 2010 | Texas Instruments TI-84 Plus Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
I have a Casio fx 300 and i am taking a stats course.
Even a smile requires the contraction of about a dozen facial muscles. So here is how you do it (not the smile, the standard deviation).
Hope it helps.
May 17, 2009 | Casio FX-300MS Calculator
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio FX-260 Calculator Logo
541 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
