Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
My new chain saw stop working. is not pulling the gas
    Brigadier General:
  • 4,088 Answers
If the saw is new, take it back to Sears for warranty repair or replacement. Good luck!
Posted on May 05, 2010
My saw just stopped on my chain got stuck and came off as i was pulling it back out of the cut, well i thought it was just the chain came off and it would be a simply fix. but its still not working right?...
First, make sure the chain break is released. (top handle pulled all the way back)
Second, remove the chain cover. You will see a tab on the chain break (a band around the Centrifugal clutch) that fits into the handle/cover. Make sure that is in place and reassemble the unit.
Did this fix your problem?
Jan 06, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
New saw idles great, but when i give it gas it stalls out
MAKE SURE WHEN YOU START A JOB YOU NEED TO PULL THE UPPER BAR TOWARDS YOU IN ORDER TO RELEASE THE CARB CHOKE SENSOR.WHEN YOU DO A COLD START THE UPPER BAR GO TO THE FRONT POSITION TO WARM IT UP OR STOP SAW JOB.
Nov 09, 2010 | Husqvarna 16" 457cc Prosumer Chain Saw ...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Apr 27, 2009 | Garden
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
2375 poulan chain saw brake is shot,how do I fix it?
You Likely by this time have resolved this. Mine messed up one day and I found a spring inside it. This spring wraps around the counter weights and pulls them together at idle speed, allowing the chain to stop, without stopping the motor. As you throttle it up and the RPM increases the spring allows the weights to push outward , engaging the chain. I have used mine without it, but I'm sure that would not be a recommended procedure, as the chain is always engaged, even when idling.
Oct 06, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
82 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
