Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have water pooling at the bottom of my freezer, why do you think this is happening?
    Guru:
  • 1,524 Answers
Blocked drain.
Posted on Apr 30, 2010
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Water pools at bottom fridgidaire freezer
sounds like your drain is plugged up....call for help on solving problem...
May 12, 2010 | Frigidaire 17 cu. ft. / 481 liter Upright...
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Refrigerator cooling but not real cold, freezer freezes ice but
***UNPLUG THE UNIT***
Take the cover off the back where the tubes go from the compressor into the freezer. If you can see into the freezer AT ALL, you have a mouse issue. Plug this hole with expanding foam. If you're getting room air into the freezer and your door seals aren't coming apart, it's usually from the rear. Make sure to melt all ice that formed in the bottom of the freezer before you plug it back in.
Jun 29, 2009 | Jason Natural Cosmetics Jason Forma...
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Water builds up in the bottom of freezer
had this happen once and my drain was clogged. in the freezer section you have to remove the rear panel. 2 1/4 screw bolts. after exposing the coils the drain hole is in the middle. i clesred the hole with my wet/dry vacuum. first sucked then blew air through it. hasn't done it again and its been 1 year so far
Apr 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
